Question about Technics SL-1200MK2 Turntable
Technics SL-1200 MK2 French - does not power up
At first, the turntable would begin normal and then go into warp mode by playing back in reverse and forward. I went to power it on today and no luck. No lights, seemed as if the tt was dead. It is set at 110v and it began to this recently.
Wondering if there are any DIY solutions or troubleshooting I am missing and if it the tt would be worth getting fixed, or would it just be better to buy a new one. I'm in Tucson, AZ, do you guys know of anyone in AZ that knows their 1200's and if it is the tt is dead, how much do think it costs to bring it back to life?
frustrated in the desert,
Luis
  • wicho51 Sep 07, 2008
    Thanks for the reply,
  • 515 Answers
The only thing that would cause a power failure would be a faulty transformer. However, since you had issues before it went dead, it was those issues which probably put a strain on the power and eventually fried it. So, you will first have to have the power transformer replaced, then have it troubleshooted to find out what is causing the warp mode.
It shouldn't cost too much to get it fixed. For something like this, we would charge about $150-180, which would cover everything. New Technics go for $400, and used ones go for about $300 - so it's up to you.
Nothing in AZ unfortunately. But if you call any DJ rental company, they might be able to refer you to someone locally.
- DJ PRO LAB
www.DJPROLAB.com
Posted on May 21, 2008
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
Technics 1200 mk2 just powered down and wont come back on
THERE ARE FUSES UNDER THE PLATTER AND BLACK COVER,REMOVE GLUE FROM AROUND REGULATOR DRIVER TRANSISTOR ON PCB.
Nov 12, 2010 | Technics SL-1200MK2 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
styluscity@gmail.com
May 10, 2010 | Technics SL-1200 Turntable
Plastic top for technics 1200 mk2 turntable
Hi, What do you mean by this pls, you need a new top or how do you fix a broken one?
Thanks Mark H (superstar DJ)
May 03, 2010 | Panasonic Technics SL-1200MK2 Turntable
Technics sl 1200 MK2
Yes and the good news is the 2SD1265 will cost you under a few pounds including P&P from Grandata Limited.
www.grandata,co.uk
Apr 09, 2010 | Technics SL-1200MK2 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Apr 04, 2009 | Technics SL-1210 Turntable
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Pitch out of Tune
That is a strange issue. Not sure what could be causing this. Are you describing your issue correctly. Or do the records sound warped? If they sound warped, check to make sure that your voltage setting is set correctly for your area (115V or 220V). This is a switch located underneath your turntable platter. Just make sure you power off your unit before making the switch.
If this is not the issue, then I have no clue what you are talking about, as I've never hear about this on a 1200 turntable, and I work on them for a living.
Please be even more specific, or if you can, give us a call here @ the shop, and maybe play a record for us. Perhaps we can walk you through it over the phone. 1.877.357.7677 ext 1
- DJPROLAB
Feb 11, 2008 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
118 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
