Question about Kolcraft Umbrella 36010 Stroller
Front Wheels Wheels turn sideways and won't turn, stroller won't roll forward w/ wheels stuck.
Did you check the levers on the front wheels to make sure the front brake isn't on?
Posted on Jul 31, 2008
The stroller wheels never worked properly from the start
Somehow it may have been damaged. I slammed the car door on the stroller, and ever since then this problem would occur. Or it could also be that the stroller is pretty cheap and does not support the weight of your child. It just may be time to switch the baby to forward facing, if you have your baby facing you that is. I called the number and they sent me new wheels. Since it was still under guarantee. Problem solved. Hope this helped. (decided to add the following). They will ask you when you purchased the stroller, the stroller has a manufacturing serial number (which they try to go by). The serial number on the stroller contains the date the stroller was manufactured. So to their benefit they want to go by that date. And not by the date of purchase. So be careful they don't twist you.
Dec 30, 2013 | Lamaze Indigo Stroller - Grey/Black
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
HI my stroller has been going sideways. Any idea what part could be broken/bent? Thanks!
Check the wheel for any hair or anything that is stuck on it. Then check the wheels and there connectors for any bent parts. Look at the joint and see if anything is bent.
Feb 28, 2011 | InSTEP 10K Double KA206 Jogger Stroller
Front small wheels get stuck all the time...do not turn/rotate easily
Take front wheels off by pressing the two tabs at the top together and pushing it down. This may need a bit of hand strength to do if your having turning problems so get daddy on the job. Next wash the wheels in a bucket of warm soapy water and clean the socket the wheels came out of. Spray the wheels and socket with silicon spray and reassembly. While at it put some spray in the handle lock hubs (THEY NEED IT). If you're still not happy Bugaboo sell a larger (Snow Wheel) for the front.
Oct 24, 2010 | Bugaboo Frog Stroller
I can't fold the buggy down!
First you need to make sure that the handle bar is in the top most position. Next the Front wheel needs to be turned sideways as you begin to lower/fold the buggy.   You must also watch the basket part so that it folds up and in so that it doesn't get stuck. I usually will also fold it forward and down so that I know the wheel and basket are in the right position.  When it is finally down it should clip into place. Hope that helps a little. :)
May 16, 2009 | Phil & Teds E3 Jogger
Front wheels keep getting stuck in swivel postion
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Feb 15, 2009 | Valco Runabout Tri Mode Jogger
Front wheel of vibe stroller sticks when turning.
exactly the saem problem with mine. Di you find a solution yet?
Sep 24, 2008 | Regal Lager Phil & Ted Vibe Jogger
Funny front wheels
remove the total front housing by pressing the 2 plastic buttons on the silver bar that holds the wheels in place. then get a small screwdriver and put in in the small hole on the black plastic part of the wheel there is a button in there but you will need to look in the hole to find it then push button with screwdriver and pull off the 2 wheels. clean and use wd40 not oil. this should fix problem if not phone dorel (they sell/own quinny) in the UK 00442082360707
May 10, 2008 | Quinny Buzz Jogger
Front wheels swivel and get stuck on each other
This is happening to my stroller and it turns out that the frame is bent. I have been unable to find a certified technician who is willing to fix it. I guess I can offer it for parts to someone.
Sep 24, 2007 | Valco Twin Runabout ATS Jogger
Front wheel problem with Peg Perego Aria single stroller
You need to regularly lubricate the wheels...Just get some WD-40 with the little straw attachment & spray into where the wheel meets the frame...Make sure you lubricate the wheels regularly...I had the same problem & call Peg toll free - that was the answer & it fixed my problem too!!
Feb 12, 2007 | Peg Perego Aria MT Rubino Standard...
Kolcraft Umbrella 36010 Stroller Logo
105 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
