Question about Maytag Washing Machines
Washer fills with water but fails to cycle thru any other stage, can hear timer running but nothing happens
  • Maytag Master
  • 17,130 Answers
Either the timer is not contacting the motor or sub devices or the motor is faulty.
So it will be good to checck the Timer controller output contacts as it runs or else the timer controller is deffective.
Posted on Sep 16, 2010
Kenmore washer model 110 82781800 won't cylce, just hear timer ticking
If the motor is going thru cycles and the agitator doesn't move, than it means the drive link snapped. cheap repair. it was made to protect the motor and trans. Read the manual before doing this. it will show you how to do it easily. iv'e done mine around 4 times. my wife keeps jamming too many clothes into the thing.
good luck
Apr 10, 2014 | Kenmore Washing Machines
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Washer is overflowing
The water input on washers is controlled by the timer which actuates the solenoid valves for both hot and cold water, telling them when to fill and when to close. I would run the machine thru a fill cycle with the washer back off, and with a voltmeter, observe if the voltage ever cuts off as the timer runs. I Another variable is the water level control. So also determine if that is working since if it failed to open the 'fill' circuit at the proper volume, you might have this overflow problem.
Aug 15, 2011 | Maytag Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwasher will not go thru wash cycles
doy you hear any sound from either in the wash cycle
Feb 11, 2008 | Dishwashers
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
