Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
I run an outdated workcentre c2424 for purposes of scanning only. After having scanned over 175 documents and retrieving the 1st page from the scanner hard-drive to download to my desktop & the appropriate file, I inadvertently hit delete all, meaning to only delete thatg 1st page (of 14). Of course, I deleted all scans. Is there any way to retrieve the deleted scans? I really don't want to take the time to scan all documents again. Thanks.
    Problem Solver:
  • 8 Answers
Check in your recicle bin. Otherwise, you have to scan it again
Posted on Sep 16, 2010
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
WorkCentre C2424 Scanning Mac OS X.
Well I haven't necessarily scanned often, but i do know if you open up a program such as word, Excel, PowerPoint, Photoshop, Corel, etc... You are given an option to scan. That way you can scan information, images and such to that program in which you use. C2424 wont give you any support because its a primary printer but the drivers should include drivers for the scanner and the computer to interconnect. If you have any photo like software on your mac. Try looking at the options at your top menu for an option or "import"
Many times it will give you the option to scan from a device.
To scan to computer its software based. Also on the Panel on the printer you should be given an option to scan. If printer is connected by USB it will be easier to detect scans from panel, but if your printer is connected via Ethernet it will be different.
I hope this helps. Try using a program that you can use to edit pictures or display. You should be given an option.
I hope this helps. Let me know what you do? and possibly i can mirror what you do on my own mac
Oct 16, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Linux or Mac OS X support for Scanning
You need to download the correct drivers for the OS.
You can go to this link:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=C2424&Xlang=en_US&Xcntry=USA&source=XOG
And download drivers from there according to your OS. Please Select proper OS otherwise you will be downloading Windows by default. On this link there is also utility programs free and so forth; you might find something useful.
Please Rate :) Porfavor
Oct 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
39,012.40:15532 red light on. workcentre C2424
Normally you can fix that by, Powering down the machine.
Disconnect all the cables between the scanner and document feeder.
Also down by the power cord there is the cable from the scanner to the processor. That is a very hard cable to get connected correctly and works loose often. Disconnect that molex connector reconnect it and take a flat blade screw driver and tighten it. Then switch the machine on. I suspect that will resolve your issue. If not here is the documentation from the manual, which offers, well not much..
39,012.4x Document Feeder Optical Test Failure Troubleshooting Procedures
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the complete scanner.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace the scanner.
Apr 30, 2008 | Office Equipment & Supplies
Scanner workcentre xerox C2424
Have you tried going to Xerox.com, click on support, then enter the 2424, then support again, then type in scanning? There is a lot of info there.
You can also call 1-800-821-2797 and ask for second level support.
Apr 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Workcentre c2424 Scan - Won't find me so I can scan to personal images
It seems somehow your address was deleted. Recreate the box on the machine and it should be ok.
Mar 29, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
1 1.
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
lamp(s).
Mar 28, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
70 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
