Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have just finished to install my OS windows XP and when i switch on my computer an error message appears telling:''failed to load kernel library'' What should be the issue and how to solve it?
    President:
  • 2,291 Answers
You hav to repair ur windows Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with RegInOut Registry Cleaner and PC Optimizer
Posted on Sep 16, 2010
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
I can't finish installing yahoo, error 0xc0150002 appears. What can I do? I'm using xp home basic. I had Yahoo 9 installed, uninstalled it and downloaded Yahoo 10, but when it was allmost installed,...
This behavior may occur if you install Windows XP Service Pack 1a (SP1a) on your computer, and do any of the following:
  • You upgrade your Windows XP Home-based computer to Windows XP Professional.
  • You reinstall Windows XP on your computer.
  • You perform a repair of Windows XP on your computer.
To resolve this behavior, after you upgrade your Windows XP Home-based computer to Windows XP Professional, or you perform a reinstall or repair of Windows XP, reinstall Windows XP SP1a on your computer.
After you reinstall the service pack, restart your computer.
try this and tell me incase if any issues
Apr 30, 2010 | Yahoo Messenger
When i turn on the computer ,an error will appear.It says ''failed to load kernel library''?
This problem is cause by a corrupted operating system. To solve this problem is to install a fresh copy of operating system again to your computer just like windows xp or others.
Oct 25, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Window could not start because an error occur in the software: load needed DLL's for kernel
hi
the error message that you are getting says that the main file that helps you to boot the computer has gone corrupted
the resolution for this problem is to do a parellel installation of your OS or uninstalling and reinstalling OS.
the site where you will get the guide for the resolution is http://gur.in
on the left hand side it will have OS installation guide follow the steps and you would be able to resolve the issue
Jul 12, 2009 | Microsoft Windows XP Home Edition
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
Power went outot two error messages:
hal.dll is not good, you need to boot from the windows xp cd and select "Install windows" then select "Repair windows installation"
Jun 10, 2008 | Computers & Internet
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
OS load failure.
The bluescreen saying about the ACPI, I had the same problem at work with a older computer. Next time you get the bluescreen read everything it says.
It tells you to press a button, I'm not sure thats why I'm telling you to read the bluescreen (windows 2000 or xp) it was f5 or f8.
You press f5 or f8 I think it was f5 since f6 is to load custom drivers.
So you press f5 when it asks you to press f6 This disables the ACPI subsystem in the setup and you should be able to install windows 2000 without any more problems. If its not f5 read the bluescreen thats where I got it!
Good luck, keep me posted and tell me if theres anything else.
Feb 23, 2008 | Toshiba Satellite A65-S1065 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
175 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
