Question about JVC Everio GZ-MG130 Camcorder
Can't connect camera to computer
I have followed all the directions and have connected my usb cable to the PC and camera, but the software won't run - says no Everio connected
  • Anonymous Oct 27, 2008
    I have this problem too. I installed the software and when I connect the camcorder the software program opens up, but when I try to backup it says no everio connected to pc. I have tried 4 different usb cables and still doesn't work. Help!
  • 57 Answers
Means either istallation is not done properly or there might be a problem in usb cable.take out the usb cable and connect it again tightly then it eill show you on the desk top that Everio is connected.
Posted on May 25, 2008
I cant load my pictures in my computer
If images cannot be imported automatically into the Windows PC, check [Precautions] below.
[Precautions]
- Temporarily terminate resident software such as antivirus software.
- Connect the AC adapter or load a fully charged battery into the digital camera.
- If RealPlayer 10 is installed, select "Tools" - "Preferences" and then disable "Automatic Services."
XXXen the digital camera is connected to the PC, if the FinePixViewer starts up and images in the digital camera are displayed, skip Steps 1 to 5 and start with Step 6.
1. Start up the PC and then connect the digital camera and PC using a USB cable.
2. The "USB MODE" setting of the digital camera may be set to "PC CAM."
Set "USB MODE" to "Card Reader" or "DSC."
*Only in the case of the digital cameras that have the "USB MODE" setting in the SETUP menu
3. Check whether or not any mark indicating the USB connection (USB, CARD READER, USB symbol with an arrow mark, etc.) is displayed on the LCD monitor of the digital camera.
If not, the digital camera and the PC are not connected properly. Check the following points.
a. Restart the PC, disconnect and connect the USB cable and then try again.
b. If the PC has multiple USB ports, connect the USB cable to another port and then try again.
If no mark indicating the USB connection is displayed even after performing above Steps (a) and (b), the digital camera or USB cable may have a problem.
4. Check whether or not "Removable Disk" is displayed in "My Computer." (For example, when the operating system is Windows XP, a FinePix icon in the shape of a digital camera is displayed.)
If "Removable Disk" is not displayed, install the USB driver again.
5. Automatic startup software (Exif Launcher) may not function properly.
Perform the following procedure.
[Windows XP]
a. Select "Start" - "My Computer."
b. Right-click the "FinePix" icon and then click "Properties."
c. Click the AutoPlay tab.
d. Click "Music files" and then select "Pictures" from the displayed list.
e. Select "Select an action to perform."
f. Select "Viewing images with FinePixViewer."
g. Click the "OK" button.
6. The Automatic Save Settings may be incorrect.
Specify the Automatic Save Settings again by following the procedure below.
a. Start up the FinePixViewer.
b. Select "Automatic Save Settings" in the "Settings" menu.
*If "*** not found" is displayed, click the "OK" button.
c. In the "Way of Saving" column, click the "Browse" button to specify the storage location.
Feb 26, 2014 | Fuji FinePix A345 Digital Camera
Problem with Olympus Digital Cameras
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as PIcasa.
Jul 12, 2012 | Olympus Cameras
My windows PC does not detect 1000D purchased pre used without eos disk utility and bundled softwares, is it a must to install these
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
May 08, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
1) how do I charge my Nikon S3000 camera? I only have a cable that connects the camera to the pc. Am I misssing a cable or is this how it should charge? 2) my pc (Windows 7) cannot find the drivers for...
Use the USB cord to charge the camera. Just make sure you're connected directly to a powered USB port, not going through a hub.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 30, 2011 | Nikon Coolpix S3000 Digital Camera
I have been using my G11 with no problems for a year. Just tried to download pix and keep getting "Communication error". Checked the cord, it's fine, turned camera off and on several times,...
hi kbailey. Turn on the camera and go to the menu. find the reset function. Reset the camera. This means you are returning it to all of the settings it was at when it was brand new out of the box. Joe
Thanks for choosing Fixya!
Nov 26, 2010 | Canon PowerShot G11 Digital Camera
How to install pc suite for windows xp ( nokia 5310)
To install the PC Suite with Windows® XP If you use Windows® XP on your computer, you may need to install two hot fixes on your computer to use your phone with the PC Suite. If so, the PC Suite will ask you to install the Microsoft® software hot fixes during the installation. To install the hot fixes for Windows® XP:
  1. Connect the USB cable to the computer and the phone.
  2. On the phone: When you attach the USB cable to the phone, a USB connection window appears. Select PC Suite.
  3. On the computer: Click PC Suite on the autoplay pop-up to start the installation. If no autoplay pop-up appears, see the instructions below to access the installation software drivers.
  4. In PC Suite, click on the first hot fix (KB943198), which re-directs you to the Microsoft® support site to download the hot fix.
    URL: http://www.microsoft.com/downloads/details.aspx?FamilyID=f2f0a7c2-3b44-4d2e-9640-e0d21818763e&DisplayLang=en
    Note:Before you download, make sure that you choose the same language for the hot fix that is set on your Windows® XP language settings.
  5. Follow the installation instructions.
    Note: The computer may restart after the first hot fix is installed.
  6. Return to PC Suite and click the second hot fix (KB945436), which re-directs you to the Microsoft® support site.
    URL: http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=945436&kbln=en-us
  7. Request the fix to be e-mailed to you and enter your e-mail address.
  8. Go to your e-mail client and open the e-mail. Click the link to the hot fix.
  9. Click Run to the File Download pop-up.
  10. Unpack the attached protected zip file. Click Ok to Microsoft Self-Extractor or select a source.
  11. Use the provided password included in the e-mail.
  12. Open the downloaded hot fix and follow the installation instructions that appear.
Note: If you run Windows® Vista, this problem installing PC Suite will not occur.
The drivers for the installation files are located on your memory card. The first time you connect your phone to a computer with a USB cable, a pop-up is often automatically shown on the computer.
To access the installation software drivers for PC Companion, PC Suite or Media Go:
  2. On the phone: When you attach the USB cable to the phone, a USB connection window appears. Select Mass storage.
  3. On the computer: Click My Computer > PHONE CARD/Sony Ericsson PC Software > pccompanion > Startme.
  4. The PC starts to initiate the PC software installation. Follow the installation instructions that appear.
  5. When installation is complete, Sony Ericsson PC Companion will start.
Note: During installation, several pop-ups may appear about Device driver installation or trusted software. Click Yes/Continue/Next to finalise the installation.
Jul 07, 2010 | Ahead Software Computers & Internet
I have a new pc and lost my software that came with my canon rebel eos xt. How can I upload my picture to the new pc? Can I find software on line? Or should I keep looking for the disk that came with the...
You can download software and more from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=11209
Apr 13, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Pc says camera is busy
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 11, 2010 | Canon EOS Rebel XSi Digital Camera
Error message, cannot connect to camera
if you plug in the camera before you down load the cd with the drivers you won;t be able to connect to the camera
Jan 10, 2008 | Vivitar MAGNACAM Binocular
Why can't my computer communicate with my digital camera?
The cause and solution may include one of the following: There is a problem with the configuration of the USB port on the computer.See the USB.html file on the EasyShare software CD. The camera is off. Turn on the camera. The battery is not charged. Recharge the battery. Some Advanced Power Management utilities on laptops turn off ports to save battery life. See the power management section of the laptop User's Guide to disable this feature. The USB cable is not securely connected. Connect the cable from the camera to the computer port. The software is not installed. Install the software. The software is installed incorrectly. Do the following to install the software correctly: Disconnect the USB cable. Close all open programs. Uninstall, then reinstall the software. (To uninstall, go to Start > Settings > Control Panel > Add/Remove programs.) Too many programs are running on the computer. Do the following to close all running programs: Disconnect the camera from the computer. Close all software programs. Reconnect the camera. The Battery Monitor or similar software runs constantly. Close the software before starting Kodak EasyShare software.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
JVC Everio GZ-MG130 Camcorder Logo
799 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
