Question about HP Business Inkjet 2230 Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired". I try for a several times to put in and out cyan ink cartridge but the message is still the same "Attention cyan ink cartridge expired". Please somebody help me what to do.I have also replaced the cyan printhead. Thanks
  • 979 Answers
Hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Posted on Sep 16, 2010
  • Jerry Umali Sep 18, 2010
    I forgot, dont pour the water, use earbuds, damped with warm water and gently dab the slot where the ink passes, until the dried ink soften.
Business inkjet 2230 shows need to replace cyan printhead, have done so twice and message keeps reappearing?
Hi
From the cartridge costs it looks as if the cartridges incorporate the printhead. If this is the case - are you using HP cartridges or compatibles. Sometimes compatibles don't work when the printhead s the problem.
If you are using HP cartridges then make sure the contacts on the cartridge, and on the printer are clean. Apart from these comments I'm afraid I'm also stumped.
Good luck.
Aug 27, 2014 | HP Business Inkjet 2230 Printer
How do I reset HP officejet 6700 Premium ink cartridges
!Ahh, this is a little tricky but I have found the best way is to wait until after normal business hours so the printer is not expecting anything.
Then sneak around behind the printer and throw a blanket over it so that I can't see whats happening, open the ink tray and remove the empty cartridge while getting out an original ink cartridge box.
This is the trick - Secretly put the refill in place of the expended original cartridge!
As you pull the blanket (or whatever you surprised your printer with) off the printer, walk away muttering how expensive printer ink is and throw the empty original cartridge in the rubbish.
Your printer should now be completely fooled into thinking it has a new original cartridge!
Jul 21, 2012 | HP Officejet 6700 Premium E-All-In-One
HP Inkjet 1000. I have installed 2 new
the printer is pretty much in a Freeze state.. so turn off the printer.. remove the power cords.. keep it out for atleast a minute and then reinsert the connections back and then try to turn on ur printer.. it will surely resolve ur issue..
May 10, 2010 | HP Business Inkjet 1000 - Printer - colour...
My printer isn't reconizing i've put a new cyan ink cartridge in,, have bought 2 from 2 diffrent stores and still says the same thing why? and i buy only hp cartridges
sir, the deskjet 1280 printer haven't a CYAN cartridge, it has a TRI COLOR cartridge.
You may have a problem in your formatter board
Apr 07, 2010 | HP DeskJet 1280 InkJet Printer
Hp business inkjet 1200, replaced ink cartridge
the error's you were getting on the CIS could have been from the chip. Try setting the date back on the computer or on the printer back 1 year. See if that makes a difference (if you still have the CIS and the printer). Best advice, get an updated chip.
Nov 22, 2009 | HP Inkjet 1200dn Printer
Black ink simply won't work
go to the control panel for your printer and disable mixing colors for "black" ink
Jun 05, 2008 | HP Business Inkjet 2230 Printer
Canon all in one printer refill ink cartridges
i have just filled my mx 310 with the jet tec refills as instructed....but do not insert the rubber bungs...instead put some celotape over the filling holes... then with a needle...pierce the celotape where the hole is( pin *****).... this set up is now able to breathe as originally designrd. Mine prints fine now this has been done (trial and error), but i might try better quality ink next fill. Its also wise to use glossy paper 230gsm or over for good results.
GOOD LUCK.
Dec 20, 2007 | Office Equipment & Supplies
HP Business Inkjet 2230 Printer Logo
668 people viewed this question
Ben Johnson
