Question about Brookstone Ionizer/ Air Purifier Air Purifier
One of the clear strings in the filter broke, how can this be repaired?
Ionic breeze wire
I tried the guitar strings, they burned out quickly. The wires that came in the unit are not steel, they are not affected by a magnet. We suspect they may be tungsten or some other type of non ferrous wire. Until we find the right wire, we cannot repair them to last. Any assistance in locating the correct type of wire for use in ionizing air cleaners would be appreciated.
Jun 15, 2014 | Sharper Image Air Purifiers
Porfessional Series Quadra
Sorry couldn't understand what you mean by fishline lines.. Kindly make it more clear..
Jun 23, 2008 | Sharper Image Professional Plus Ionic...
String line broke
what is the model number as it could be anything, there are a few models made and some have more that other do, ion senor bars and diffusers etc it could be any of these.
Mar 24, 2014 | Air Purifiers
The string inside my ionic breeeze quadra is broken. Is it possible to fix it
Not so fast with the screwing part. Go to a music store, buy the G string wire(008)gauge- at least 41 inches long- for a guitar.
If you have a digital camera make a video/pics history of your dis-assembly steps.
Remove the ozone eliminator-by pulling it off the tower.
Start with the base 4 screws, followed by the 2 collar screws at the base.
NOTICE that there is a space between the two halves at the bottom. I paid NO attention to this space-boy did I ever try to snugly close that one before I looked at another one to see that this separation is there for a reason.
Next: remove the "TINY"12 screws - 6 on the front/back side of the units ribs-look for these.
Take pics of each step. You will be happy you did this.
Store all of these diff. screws in separate jars.
Open the unit now like a wallet. Notice that the sloped top control button/light module can now be removed. See those 2 black square plastic covers-they hide a spring and an upside down W shaped wire holder. The broken wire can now be removed. If you are lucky, you may be able to to twist your new wire-after pushing it through the cleaning bead -with the one going down to the bottom module. Mine was too brittle and broke apart as soon as I touched it.
Remember: The 2 wires you see are just one 41 inch long 008 gauge guitar string.
They thread through a signal contact bracket at the bottom of the unit that is activated by the breaking of the wire to turn the unit OFF. Getting to this bracket is somewhat difficult and requires patience. Take a lot of pics to be able to reassemble the S 1637. I pulled the 41 inch long string under this signal bracket, evened off the ends, moved the top module down 2 inches and twisted the ends around the W shaped bracket that compresses the spring.
Honestly, I had to adjust the spring two times because I left off the cleaning bead. Now just reverse the steps and you got your unit working. The new string seems to push a lot more air.
Before you replace all of the screws, fold the unit together, insert the blades , put 2 sets of veggy rubber bands around the top and bottom and plug in/turn it on. Mine works now better than new. Did I mention that I had to do 2. The second was done in 2 hours.
Good luck.
totrosko@yahoo.com
Mar 28, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
Broken "guitar string"
No. This is not repairable. You will need to purchase a new cell from your local hvac contractor.
Oct 02, 2009 | Sharper Image Air Purifiers
Filter for sharper image ionic breeze model s1730
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station.
You might be able to pick up spare parts if you scour eBay long enough.
Jun 22, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Air filter lid latch broke
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
Mar 30, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Nov 03, 2008 | Sharper Image Professional Plus Ionic...
Broken Wire
Go buy a couple of .09 guitar strings from your local music store. This is how I fixed mine. You need to very mindful of the way it is assembled whilst taking it apart so you can duplicate the assembly in reverse:)
Apr 29, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Broken wire on filter grid
Not easily but it can be done if you have superior skills with small tools.
Nov 17, 2007 | Oreck XL Professional Air Purifier
Air Purifiers Logo
Top Brookstone Air Purifiers Experts
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
