Question about Danby DKC645BLS Compact Beverage Cooler
Danby DKC644BLS Chill 'n Tap Kegerator I can't keep a consistent temperature. No matter where the temp is set it doesn't stay. One minute it's 36 and the next minute its 49. Please help. My beers getting warm!
  • 619 Answers
SOURCE: new danby kegerator - tastes like rubber hose
you may report the problem of taste of beer the store where bought it , byu the when it new smell strange but it better clean in second time by flushing of water before you attache the beer tank, for the time the fume of rubber connection still inside on that machine , (in purified water need to back wash in order to make a purified water good taste and clean, ) the term use of that machine is "flushing " .
Posted on Jan 01, 2008
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Posted on Aug 07, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Danby Kegerator and the thermostat
hello sir/mam
please check and change the temp sensor then see its working
Posted on Sep 15, 2009
  • 207 Answers
SOURCE: i have a danby kegerator and i just tap the keg
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Posted on Feb 24, 2010
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
I have a Danby Kegerator I purchased at Sams Club a couple years ago. The temperature readout said LE at one point and now it will cool down when I first plug it in, but then it warms up to between 50-70...
contact mark pasieka for a repair.... mail in the board and he can fix it and send it back.... if you live in the chicagoland area he is a liscensed for all types of refridgeration, and since he has 2 degrees in electrical engineering he is especially proficient when the issue is electrical in nature...
mark.pasieka@gmail.com
Sep 21, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
http://www.amazon.com/gp/product/B0002EAL58
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
May 10, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
How to make the kegerator colder
From the operators Manual page 14:
http://www.manualnguide.com/dl/20835/
Each depression of the up or down arrow will
increase or decrease the temperature
incrementally by 1º (F/C) until the desired setting
is reached. The temperature can be set between
36-46º F (2-8º C).
Danby Phone:
1-800-263-2629
*Note: the display will flash for 5 seconds from
the time the last button was activated before
resuming display of the internal temperature of
the cabinet.
Feb 05, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby kegerator not cooling
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Touch pad
I have them in stock if your md# is DKC645BLS or DKC644BLS would be $22.75 after tax and get too you in 3 -5 days my number is 509-928-7176 can do visa or master over the phone.
Aug 20, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Temperature on Keg Cooler (DKC644BLS) is dropping below freezing
Mine did this as well. last night the diplay read "LE" and the temp controls and the C/F buttons were unresponsive. I called Danby. Although I was on hold for 30 minutes, when they did answer they were very helpful. As mentioned elsewhere here, the touchpad has gone bad. You can order it right over the phone. The price of the touchpad is only $2 and shipping is $7. I ordered 2 of the touchpads (why not, right?) and the shipping was still $7 for the both. # for Danby is1-800-263-2629. Make sure your phone is charged.
Jul 23, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
419 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
