Low screen resolution - Computers & Internet
    Problem Solver:
  • 5 Answers
If you're using a Windows based system, Go to a blank area on your desktop. Right click with your mouse. Go down to the bottom and choose properties, then choose the "settings" tab. Then slide the bar under "screen resolution" to suit your desired setting. Then choose save. or OK to exit
Posted on Sep 16, 2010
My Nextbook Windows 8 tablet won't access desktop, and screen resolution is too low, but I can't make any changes.
Check screen preferences in the control panel to set resolution and other screen options.
Feb 09, 2015 | Nextbook Tablets & eReaders
Screen flashes colors
The issue (flashes" colored screens) you're facing could be related to drivers and could be resolved by updating the display drivers. Without the correct driver, the hardware or device that you want to use won't work properly.
Also refer to:
http://windows.microsoft.com/en-us/windows7/update-a-driver-for-hardware-that-isnt-working-properly
Let's try to boot the computer in low resolution mode and check the issue status.
Low resolution starts Windows using your current video driver and using low resolution and refresh rate settings. You can use this mode to reset your display settings.
Refer the section:
Enable low-resolution video (640×480)
Apr 24, 2014 | Microsoft Inspiron Notebook
My computer's screen resolution is too low
Hello to adjust your screen resolution, right click on the desktop and either click properties for Windows XP or screen resolution for Windows Vista/7. Then for XP click settings and you will see a slider bar where you can adjust your screen resolution. For windows 7, it will be on the screen that opens up, just slide the bar into the resolution you want.
Thanks for using FixYa!
Aug 15, 2011 | Computers & Internet
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
The Screen turns black when I attempt to start windows normally. It sounds like windows is starting, but nothing appears on the screen
It sounds like windows has been set to a screen resolution beyond the limits of the capabilities of the built in LCD. Luckily windows has a menu that allows you to change to a highly compatible low resolution mode. To select this mode, start tapping the [F8] key just after the HP/Compaq screen when the computer switches on. Hopefully if you pushed the button in time, you should be presented with a menu. Use the up and down arrows on the keyboard to select the option that says either "Enable VGA Mode" or "Enable Low Resolution Video (640x480)".
Windows should now load, but everything will look extra large. To fix this, go into your display properties (right click on desktop and select either "properties" or "screen resolution"), and choose the recommended screen resolution.
Dec 24, 2010 | Compaq Presario CQ60-220US PC Laptop
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
The sound is working but the screen flashes on and then goes off completely.
Try to boot you computer in safe mode (for low resolution) step down the resolution, restart and try step by step to upgrade the screen resolution.
Stelios.
Feb 21, 2010 | Coby 20" Flat Screen TFT LCD TV Monitor
Screeen Resolution too low
600x800 for printer.
go to control panel display properties settings tab
click on advanced. click on monitor tab and uncheck hide monitors
uncheck hide modes
click ok. change resolution to 800x600.
Nov 25, 2009 | HP Mini 1000 Netbook
Low resolution screen
have u loaded the display drivers?
right click on the screen and go to properties and on the last option settings go and change resolution
May 06, 2009 | Dell Precision 360n PC Desktop
Adjusting the screen resolution
Right click the desktop > Properties > Settings Tab, you can change the resolution in there.
Jan 02, 2009 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
