CD Player only works for a few seconds
When I put in a CD it plays only 5 to 7 seconds then stops playing .
I have tried useing a lazer disk cleaner but it did no good .
  • 2,334 Answers
I will say that the DC motor that transport the laser Assembly to read the info from the CD is defective or it could also be the plastic gears.
The only way to fix it, is to replace the whole assembly where the motor is mounted. You might be able to find this assembly without the laser assembly.
Let me know if you need further assistance.
Posted on May 17, 2008
  • 13,433 Answers
Most likely the lens mechanism / lens is faulty and would need to be replaced.
  • 3,037 Answers
Have you tried cleaning the lens with some isopropyl alcohol and a q-tip? Sometimes the disc cleaners don't work and this does. You will need to open it up and try this. Also, this I presume happens on multiple cds, correct? Please let me know on this, you could also try cleaning the disc on the bottom with a soft cloth. Perhaps the player is dusty. Please try the above suggestion and let me know how it goes, thanks.
  • Benjamin Patri
    Benjamin Patri May 21, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
    Genius:
  • 3,422 Answers
Few troubleshooting steps you can try:
First try a hard reset by unpluging all the cords from the back for 30min and then plug it back in.IF this doesn't help then do the following:
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.You can also restoe the settings to factory defaults by inserting a toothpick or a small paper click in thehole in the front..
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
My cd part of aiwacd3 wont play any longer. i looked through the top window and it appears that the disk does not fit centrally under the playing head sometim and then the head spins a few revolutions,...
hi there.
Although CDs are still the preferred method of audio distribution, CD players are quickly being phased out in lieu of MP3 players. If your old CD player stops working, it might be a little panic-inducing, but fear not. If the CD player turns on but does not play CDs, then the problem is not with the power cord or the circuity (which are generally more expensive to repair rather than fix) but with the lens. There are several troubleshooting steps that you can take to fix a CD player when it won't play.
Step 1 Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
Step 2 Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Step 3 Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
if you need more info go to this link.
cd won play Google Search
Dec 11, 2017 | Audio Players & Recorders
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
Whe i put the cd in iy doesnt play properly. it plays and stop for a few second and then plays again.
Try cleaning the lazer eye, Buy taken the cover of of it, Use a Q tip. If that dooesn,t help. The lazer is shot , It is a verry costly repair, Just go end buy a different one,
Nov 11, 2012 | Pyle PRO PDCD210 -Dual CD Player w/Quick...
Cd says loading error and wont play
disks re lazer screen needs cleaning disk cleaner
Aug 12, 2012 | Alpine IVA-D100 6.5" Wide LCD w/DVD/CD/MP3...
Toshiba DVD SD73000KU will not recognize ANY disk
hi
have you been tried to clean the lazer lens with a cd lens cleaner. if doesn't work you can do with manual cleaning using a fiber cloth moist with alcohol damped gently the laser lens which may be dirty causing not to detect a disc. now if those tries still doesn't work your last option to make an adjustment on the speed settings of the drive motor. at the lower portion of the lens their is a trimmer adjustment, you can used a small flat head screw driver then try to adjust the trimmer just a little bit counter clock wise, make sure the player is unplugged for safety. then try to plugged it and turn on the player, insert now a cd and observed. if the motor doesn't rotating, removed then check if worn out, replaced a new one if needed.this will worked now.
hope this will helped thanks for consulting the fixya.
Dec 25, 2011 | Toshiba Televison & Video
Disks skip and do not play
try putting a laser disc cleaner through the player it will clean the lazer allowing it to read correctly
best of luck
Add a comment
  • sonicboomele
  • 1 day ago
sonicboomele_0.jpgthis is what they look like the small brushes clean the laser
Reply
Dec 29, 2010 | Sony CDP-CE375 5-Disc CD Changer
Cd player won't play first track
there is a cd writen problem with the 1st track.......
Nov 18, 2009 | Audio Players & Recorders
CD player won't play after pressing the play button on all tracks
This problem is usually caused by dust or smog accumulating on the laser lens assembly. Unplug the unit and remove the top cover. Take a cotton swab and wet one end with glass cleaner. Wipe it gently across the lens (do not apply pressure). Use the other end of the swab to dry the lens. Reassemble the unit and test for skipping or non-playing discs.
Feb 02, 2009 | Audio Players & Recorders
Dvd wont play in mini hi fi system
First, you should never use commercial cleaners on CDs or cassette heads. They can create more problems than cures.
Unit may have bad disk motor or optical pick-up
May 01, 2008 | Audio Players & Recorders
Cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Sep 07, 2007 | Aiwa CSD-ED27 Boombox
226 people viewed this question
 Grubhead
Grubhead
