Question about Whirlpool Calypso GVW9959K Top Load Washer
I have whirlpool washing machine FSAN652, White Magic. water supply in this machine is not working. Tap water reaches up to entry point of machine , but not getting into machine. All other fuction of machine is seem to be normal. It is to be noted thta there is lot many Rats in the house . Pls advise what steps can be taken to make this machine fuctioning , meanwhile we are taking steps to eliminate Rats from thta area.
  • 121 Answers
SOURCE: Washer/Dryer
it depends if you have a combie boiler if not should be cool but if so would recomend a screw on tap connector from any good hardware store for your cold pipe
Posted on Mar 03, 2008
  • 97 Answers
SOURCE: I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Posted on Jun 29, 2009
SOURCE: GIVING ELECTRIC SPARK INSIDE THE WASHING MACHINE DURING RUNNING
washing machine motor sparks during spinning
Posted on Oct 03, 2009
  • 262 Answers
SOURCE: My Whirlpool Washing Machine 123
check to see if drain hose is lower than the control panel if not it will need to be raised.if it is make sure air can get by the hose as it goes into the drain e water out of the tub
Posted on Nov 02, 2010
  • 6277 Answers
SOURCE: What to do if whirlpool awz 50e washing machine is
Providing that the tap is turned fully on and the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
Good luck,
John C
Posted on Mar 27, 2011
I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
whirlpool have a good fault code list on the net
go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
Jun 28, 2015 | Whirlpool Washing Machines
No water going into machine
Filter clogged at the pipe entry point?, Does it click when you set it going for the water to enter? (Daft question now) Is the water tap on at the supply?
Sep 30, 2014 | Zanussi Washing Machines
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
I have a Whirlpool 'Splash' 'White Magic' Washing Machine. It was working well except small noise. However, since yesterday it is not sucking water from the tap and all other functions of...
simply put, washers dont **** water from your tap they simply use a valve that opens or shuts to let the water flow through from your taps similar to u turning your tap on just this is done electronically in your washer, if uve got no water coming in your valves are stuck or broken, they are cheap and really easy to fix
Jun 17, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool white magic washing machine 64408036-dlf is not retaining water
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 16, 2010 | Whirlpool Washing Machines
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
WFS1071AW is my type of whirlpool front loader
Hello baud Welcome,
You said the water entry into the machine is fine with nothing blocking it. But you keep getting the red light on for "water tap closed". At one point the water did start flowing in but soon stopped and turn on the warning light again. Please suggest how to fix it??
I believe this sounds like the screens are dirty and stopping water flow so it shuts down!
Dry all of the below suggestions.
Washer displaying code message and or tone sounds
“F20” (Water Inlet Problem—no water or insufficient
water supply)
First:
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.Leave power off for 5 minutes. This will reset the system!
Check the following:
Are water faucets completely turned on?
*****Are screens at inlet hose connection to washer clogged?
Remove hose from washer an clean screens at water inlet!
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Let me know how you do.
Thank You Huuum
Please remember to leave a rating!
Oct 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
137 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
