Question about Fujitsu Siemens Siemens Basic Line B17-1 17" LCD Monitor
Fujitsu siemens scenicview p17-2 monitor flicker. Some time ago flickered about 20 min. after power on, but now always. Two monitors and the same bug.
  • 21 Answers
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Posted on Oct 24, 2011
  • 23 Answers
IF you do not think it is the monitor, replace (if possible) the cable from the computer to the monitor. Sometimes the cable can be loose. Then, check the connection at the video card. The video card may be loose or may need to be replaced. Also, before you decide none of the above is what you want to do, verify that the refresh rate in the computer display control panel is set to the speed the monitor can accept. (right click on the desktop and pick properties then screen resolution/video/monitor options). Screen refresh should be 60hz +/- as a basis and adjust from there.
I really suspect the cable.
Brock
Posted on Sep 16, 2010
4 Suggested Answers
chalkperson
  • 147 Answers
SOURCE: No sound
Are you connecting the speakers to the green port on the sound card. If so, check in "Control Panel" that the P.C can see the sound card and that it is the "Preferred" play back device.
Posted on Sep 13, 2009
Testimonial: "Your advise on the audio plug I'm sure is the problem. I got the monitor with no manual and no cable.Thank you for all your help. John"
budmrtn
  • 11361 Answers
SOURCE: My Fujitsu siemens monitor fades after some tim
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 11, 2010
  • 10406 Answers
SOURCE: Fujitsu Siemens Premium Line P17-1
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Posted on Sep 29, 2010
Osd locked fujitsu
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 19, 2014 | Fujitsu Siemens Siemens Basic Line B17-1...
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
There is a problem in LCD, when become ON so start flickering continuously
Need more information. Does it switch on / off intermittently or the screen brightness is varying ? Refit / Replace signal cable.
Samir.
Feb 07, 2011 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Monitor in on/off loop. If hold select button down you can see the PC is diplaying but monitor keep going off then on. Also can hear the relay clicking in the monitor.
That is a bad one. Sounds like you need a new relay. I know that is no help. Check the power cord, (believe it or not, they can have too little power going through if they get damaged or weakened by something). Check CLOSELY the video cable to computer connections. touch the ends and nearby cable ends while observing monitor to see if it flickers at the same rate of your movements. Try another monitor to see if it does the same thing. I can't help with much else on this. Good luck
Brock
Jun 02, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
Screen flickers from red to blue to green. Must be a loose wire or contact somewhere. Is there a manual for opening the P7120?
flickering means your monitor is faulty. you might need to replace it.
if machine is under warranty i believe the replacement is free.
Jul 01, 2009 | Fujitsu Siemens LifeBook P7120 Notebook
Samsung SyncMaster 510N Monitor is flickering and blinking like a Tube Light After playing games for 20-30 min . It flickers when some darkness comes PLEEEZE help me
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
rahul
Feb 22, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Fujitsu Siemens Siemens Basic Line B17-1 17" LCD Monitor Logo
1,160 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
