Question about Insignia NS-DV2G MP3 Player
Turns off and on ..crazy insignia!!
Well the problem is that i want to charge it, n i put it on the usb thing, then it turns on, and say "serching 4 pc", but then... turns off, n after like 5 seconds turns off, then turns on again :S! idk what 2 do!
  • Chris McWethy May 11, 2010
    Hey Vanilla_1,
    Are you plugging this unit into the front USB ports or the rear USB ports and what kind of computer are you using?
    Some PCs don't have enough voltage on the front USB ports to power some devices...this Insignia unit is one of them.
    If you are looking to just charge the unit, a Dynex iPod AC charger pack will also work...or any other AC to USB charger for that matter.
Ok if you plug it in and it blinks on and off, its because you need to get to your system properties, device manager, and change the settings from an mtp device to a mass storage device, by manually selecting your driver.
Posted on Jul 09, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
Yes, some systems don't provide enough USB power for battery recharging of certian devices. You may need to purchase a separate USB power adapter.
Posted on Jul 04, 2008
I can't find the pairing codes for my ns-bthdst
the code on the PC side should be 4 zero's, there is no code to set on the headphones side of things, just power the headphones on and on the PC set to serch for new devices.
Feb 17, 2011 | Insignia Bluetooth Wireless Headphones...
How do i successfully charge the Insignia kix mp player
To charge your player, turn your computer on and connect the player with a USB cable. More details can be found in the owner's manual.
Sep 22, 2010 | Insignia Kix MP3 Player
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Keeps freezing up after downloads
My new Insignia NS-8V24 player, that I've had for 3-4 months, won't charge. I've used charging USB lines I have to charge it on every computer possible, but it won't charge. It would turn off and on for a few seconds and turn off again. I do not know what to do, because I cannot download music into the Mp3 player if it cannot be turned on. What should I do?
Jun 09, 2009 | Insignia NS-DV2G MP3 Player
Insignia Bluetooh Headphone won't turn on. but can charge
Well i fix it putting on power and pressing both volume buttons for 15 seconds. Then he turned on with no problems
Mar 22, 2009 | Insignia Bluetooth Wireless Headphones...
Not getting Charged
If you mean the Insignia NS-BTHDST or NS-BTHDP, I read elsewhere in this forum that you can reset it and that might work. See the manual. Basically you hold the volume up and volume down together while the charger is plugged in. The instructions were vague and mine did not reset nor show a purple light as indicated in the manual.
However, after trying that a couple of times, I accidently got it to work by pressing the phone/play button twice. Press it normally, not the long press you use to turn it off and on.
So in other words, plug it in to the charger. Press and releas play. Press and release play.
For me, the charge light turns on and it starts charging. I hope this helps.
Mine is new too, sort of. It was an "open box" from an ebay seller. I may return it anyway, since it is clearly NOT behaving correctly. You shouldn't have to press buttons at all to get it to charge. I know because I have another one.
Bon chance, mon ami.
Oct 10, 2008 | Insignia Bluetooth Wireless Headphones...
Mp3 insignia sport
is the battery in correctly and is the usb cable fully inserted on the computer end if your going throug a usb multi-port hub make sure its not over loaded with too many devices
if no hub try a different usb port or a different cable
Aug 10, 2008 | Insignia NS-DV2G MP3 Player
Won't Charge
On some systems, the usb does not supply enough power for battery charging, so it briefly comes on, then goes off. Also there are power adapters with a USB plug on them for charging things that use the USB for power. You may have to end up buying one. Though they are very usefull now that more and more devices use the USB for battery charging power.
May 24, 2008 | Insignia Pilot MP3 Player
Insignia NS-DV2G MP3 Player Logo
50 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
