My toshiba laptop is on trying to hibernate permanently I can only turn it off by lletting the batteryrun down
  • 490 Answers
If you hold down the power button, it will trigger the hard power off. Hold it for a few seconds. This will bypass most shutdown issues.
You can also just pop out the battery in an emergency.
Good luck,
Farmerbear at FixYa.com
Posted on Sep 16, 2010
Why won't my toshiba satellite laptop turn on?
have you tried pressing space bar (maybe its in hibernation mode)
or try holding power button for a few seconds (10) then turn it back on. as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite Computers & Internet
My toshiba computer has turned off and a red light flashes when I try and turn it on again
Sounds like there is no power to the laptop so teh laptop has gone into hibernation. Make sure that the laptop has working mains power.
Dec 10, 2013 | Toshiba Satellite Computers & Internet
Cannot get my Toshiba L505 Laptop out of Hibernation mode
you may find this helpful try it soon and let me know if it works
click here
May 16, 2012 | Toshiba Satellite L505-S5966 Notebook
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
My laptop doesnot come back from hybernation. I have xp on my Toshiba laptop.
Common problem with a lot of laptops.
I recommend you shut it down as opposed to let it hibernate or just turn off hibernation
Start... Control panel.... Power options... Hibernate ... uncheck the box "Enable Hibernate"
Jan 03, 2011 | Computers & Internet
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Hibernation
This doesn't sound like a hibernation problem, it sounds to be much deep, motherboard deeper, but let's rule out the hibernation. Unplug the laptop, take out the battery, this will completely shut the machine down. Then put every thing back and restart. If it starts, then disable the hibernation mode in the display properties, screen saver tab, under the button that reads power. If it doesn't start, then the problem is with the motherboard or one of it's components. Take it in for a professional diagnostic, they will be able to tell you exactly where the problem is and if it's a replaceable component.
Jul 23, 2008 | Toshiba Satellite M105-S3004 Notebook
Can't get it out of Hibernation...
my toshiba laptop went into sleep hibernation mode,& all i could get was the cursor on screen but nothing else, omg could not get it out of this mode for about 5-10 minutes,so i held the on/off button down for 10 seconds until it definately switched off,then was able to be reboot the laptop,but took some time doing this......
Oct 30, 2007 | Toshiba Tecra 8100 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
