Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Robinair 34788 after recovery give a (oil drain error 2) message. What could be the cause?
    President:
  • 180 Answers
You need to replace oil drain solenoid
Posted on Sep 17, 2010
  • 1 more comment
  • Hasan Khan Amran
    Hasan Khan Amran Oct 01, 2010
    You can also check oil drain switch and oil drain harness on main controll board
  • Hugo Herrada Aug 01, 2013
    Hello Hasan i wish to know where is located that solenoid? I have the same trouble in my robinair 34788 Im located in Venezuela and technical service is not good and a little expensive
  • Kevin Jay Friesen Sep 03, 2013
    Hasan, I have found many times the little oil drain hose is clogged and just needs some air pressure applied to it in order to unclog the issue.
We have a robinair 34788 and it wont recover
Does it flash any codes on the screen when you attempt to recover? You'll want to check the inline filter as well as the condition of the pump oil.
Aug 03, 2015 | Robinair 34788
Freon blowing into oil
What is your question? Freon, refrigerant, and oil flow together. Sometimes an acumulator/receiver/oil separator is used to keep the compressor from flooding with liquid
Jun 05, 2015 | Robinair Cool-Tech 34788 R134a Refrigerant...
WILL NOT INJECT OIL
No service manual?
What about support from the folks
you got it from--assuming it is in a shop?
Call Robinair
Jul 15, 2014 | Robinair Cooltech 34788 R134a Automatic...
How to replace tank fill solenoid on robinair 34788
No, you cant remove tank fill solenoid until close low (Blue) and high (Red) side valve on ISV tank (Internal storage vessel). see attached picture to identify Tank fill solenoid. 39b3bb9f-14fe-4040-a186-3a3a23d2848e.jpg
Jun 18, 2014 | Robinair Cool Tech 34700Z Recovery,...
34788 will not inject oil
0227afb4-3369-43df-9070-e7a9163e41c8.jpgYou have to clean oil injector solenoid or replace the new one. To find oil injector solenoid (S3) in the manifold assy. see the attached picture marked with green arrow. Hope this will solve your problem.
May 30, 2014 | Robinair Cool Tech 34700Z Recovery,...
Robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
Nov 04, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34788 machine and when I am recovering a system for service the recover feature no longer completes down to the oil drain. Its like it gets stuck on recover.... and by that I mean it...
It's sound like problem with oil drain solenoid or harness. please check harness of oil drain solenoid. If harness is ok & connected with relay board then you need to replace oil drain solenoid.
Oct 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
High presure rest on robinair 34788
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robinair 34788 machine having same problem.You can try the following 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Aug 09, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34788 not pulling a vacuum
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robin air 34788 machine having same problem.You can try as follows 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Jun 06, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
3,809 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
