Question about Health & Beauty
Took apart Remington MPT3500 to clean out blades(2). Now I can't seem to re-assembly it correctly, so that it works as before!!??
EwingElect
  • 276 Answers
SOURCE: Cannot put blade assembly back together
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Posted on Apr 08, 2009
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
  • 61 Answers
SOURCE: I took them apart to clean and now I can't get
take time, don't rush
Posted on Jan 05, 2010
  • 10 Answers
SOURCE: oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Posted on Aug 03, 2010
SOURCE: I can't find the manual
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Posted on Feb 28, 2011
I have a norelco arcitec shaver and the heads no longer turn. I haven't had it that long so of course very disappointed with the razor. I would like to take it apart to clean it, thinking there may...
You are problable correct in thinking that the blades are clogged up. Unfortunately, you are also correct about the terrible design. The blades on Arcitec models can not be removed from the head assembly for cleaning
complaints can be made to Noreclo at 1-800-243-3050
Replacement head assembly can be purchase from shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
May 10, 2011 | Health & Beauty
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Remington R7130 electic razor cleaning
Hello, my mom brought me this for christmas, all u need to do is press the little clip underneat the 3 blades and the main bit will life up. If you want to clean the 3 blades, push the blade in and twist it left, it will move slightly then just lift it up and clean away.. Aparantly u can rinse it with water but i havent tried that yet. U will notice that each blade has a little ball shape thing on the black bit surrounding the blade, this is the sign to show u were to put the blade back on, as it should be inline with a little indent in the black thing surrounding it.
Dec 20, 2009 | Remington Health & Beauty
Aug 13, 2009 | Andis Health & Beauty
After two weeks use of my new Remington R5130, now one of the three heads keeps popping off during almost during every shave. Any suggestions?
My R5130 kept falling apart when I shaved. I really like Remington Shavers (Spectrum Brands) and have had good luck with them until the R5130 model.
Two points.
1.) -THEY SHIPPED ME A NEW HEAD ASSEMBLY (BUT)- The original one I got had poorly formed plastics tabs on the blade retainer (head) I Googled Remington Shavers and used their Consumer Service tab to request a fix. They sent me a new head assembly free of charge and yes it worked much better. However, it eventually the heads started falling off again.
2.) RUBBER BAND FIXED IT - I looked it over again and thought that the range of movement and forces on the assembly pieces was just more than the design could handle so I looked for a way to contain some of the movement. I slipped a single thin (1/16"x1/8") - 2" diameter rubber band around the three head assembly and the problem has been completely eliminated. I can shave normally now. The rubber band nearly disappears under the black head flanges so it doesn't even look bad. The shave is a little firmer now but it still has most of the flexibility of the original design.
This simple fix will be a hard one for Remington (Spectrum Brands) to adopt but you might help spread the word. I am sure they will avoid this problem in the next models.
Jul 08, 2009 | Remington R510 Electric Shaver
Apr 07, 2009 | Norelco Reflex Shaver 5885XL Electric...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
