Question about Samsung HCM4215W 42" Rear Projection Television
Samsung HCM4215 No Power
I was reading your advice about a individual who was experiencing power problems with his Samsung HCM4215 television. (
I'm having the same problem too. The picture on the television was fantastic now convergence problems and the set has been rarely used. All of a sudden I started to get a loud popping sound when I turned on the television. The television functioned fine, but only on the initial start-up would I hear the popping sound. After about a couple of months of the popping sound, the television stopped turning on. No power.
I followed your instructions. I first unplugged the connectors on the convergence board to see if the set would turn on. No luck. So now I'm down to either replacing both the power/deflection board and STR type regulator IC or just one of the two. My question is: do I need to change both? I know what the power/deflection board is (AA94-08574A), but I don't know what the STR type regulator IC (AA13-00105A) is.
Can you please help me? I don't know what to do next.
I have a 14" samsung hitron tv with a STR problem.The STR got burn beyond identification. Could you please help me with the value of the STR or a schematic diagram for this TV?
My email address is
Posted on Jun 13, 2008
Our Samsung ML-1665 printer will turn on briefly and then turn itself off again, and become unresponsive. How can we fix it?
pl. check the right side of the cart. compartment of the printer ,the crum contacts may be short, If you have made firmware update and power off has done in that case replace the main board.
Sep 29, 2014 | Samsung Ml-1665 Monochrome Laser Printer
TV clicking on and off with colored screens and noises, not power supply capacitors this time.
Sounds like a main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Samsung LN46A630 46 in. LCD HDTV
My LCD TV Series 530 keeps on blinking and would not turn on. why does it keep doing that?
I've experienced similar issues with a 42" Samsung LCD TV. From what I've read online, I believe it could be a problem in the circuitry of the power supply. Apparently, Samsung used under rated capacitors in the power supply and the result is a turn on delay or blinking on and off. If this is the case, then the capacitors would need to be replaced to fix the issue.
Aug 07, 2011 | Samsung Televison & Video
The Samsung HCM4215 Rear Projection TV was playing and all of a sudden the Picture disappeared but the audio kept on. Then I switched off the TV and tried to switch it on but the TV is not turning on. The...
Hi kantraman,
The main reasons of your problem is the bulb which is already came to its end. The unit will automatically shuts off when it sense a bulb failure. But before you replace the bulb I would advice you to work first on itspower supply. Look for open fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms like what it showing now. If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
The lamp is usually located at the side of the tv.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Feb 23, 2011 | Samsung HCM4215W 42" Rear Projection...
Samsung 46" flat screen clicks
Your experiencing a potential short upon start up. Ensure to contact a licensed individual to assist you before you continue.
Jan 08, 2011 | Televison & Video
My dell gx270 power supply has been burnt how can i repair it
If the power supply has been burnt, individual electronic components likely failed due to a power surge or other issue, and you may have experienced a short within the unit. Unfortunately, due to advanced difficulty and low cost, power supplies generally are not repaired, they are replaced instead.
Aug 04, 2010 | Dell (1N405) 180-Watt Power Supply
Samsung SR-S2028DVW american style FF keeps defrosting
I would suspect the thermostat or the defrost timer is malfunctioning.
Jul 18, 2017 | Samsung Refrigerators
My Nissan Xtrail loses power when I hit 4500 revs.
well it can be driven up to 4500 rpm,i advice u to go to make a diagnostic on the e.c.u,there is something that is not working well a sensor,do that diagnostic u will sure get the fault,and can fix easily
Sep 01, 2009 | 2004 Nissan XTerra
Flashing power access light ... laptop not reading drive at all.
It is the Problem With your Battery of the Laptop ........ Replace it
Apr 24, 2009 | Computers & Internet
Samsung HCM4215W 42" Rear Projection Television Logo
271 people viewed this question
Jerry Greenberg
Jerry Greenberg
