Question about HP Office Equipment & Supplies
I am not broken, but want to know if there is a way to make my Deskjet F4100 All=in=One Color printer only print in black so that I can save my color cartridges.
  • 975 Answers
YES !! theres a way . . . go to "PROPERTIES" , on top tab go to "COLOR" , then check box where it says "PRINT ON GREYSCALE" , then check "BLACK CARTRIDGE ONLY"
hope this helps AJ
Posted on May 17, 2008
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
I have a HP Deskjet D4260 and when i print something using HP Deskjet D4200 series its black and white. I need the pictures to be in color
U must be using HP74, 75 cartridge for your printer.
There are few reasons you are getting black and white (gray)...for printing job.
1. No color ink.
- If you are out of color ink.. that's what it happens.
- check your ink level through control panel.
2. Printer set up. (I think this is pretty much the reason you are not getting color)
- First, check your printer setting.
If they are on gray scale mode, pls chang to color.
How? when you click the print (through file manu), there are option for control panel on your screen. Click that option and will see some detail option you can choose from size, print quality.
Among the print quality option, pls choose, color mode instead of gray mode. That's it.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Deskjet D4260 Printer
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
My deskjet 5550 printer stopped printing in color it only print black ink i have replaced the color cartridge still only prints in blank only; i have tried calibrate printer and clean cartridge options;...
If the Cartridge and printer alignment is successfull and you are still not able to print in color, mostly the Color print is disabled in your pc
Click on START Button
Open Printers and Faxes folder
Highlight the Printer icon for Deskjet
Right click on the printer icon and choose Printing Preferences
Under Printing preferences, you will find Printing mode - It must be on BLACK or GREY SCALE, Change to COLOR/ ALL
try printing.
Jul 03, 2010 | HP DeskJet 5550 InkJet Printer
I have HP Deskjet D2466 Printer and when i want to print with color cartridge, the black color would be printed as blue color... My black cartridge was exhausted so i only can printed with color...
when the color cartridge has to make black, it uses all three colors. printing blue indicates that the color cart. is getting low on red and yellow. get a new black cart. and a new color, 'cause it' s coming due.
Let me know
May 18, 2010 | Office Equipment & Supplies
How to set hp deskjet 3550 inkjet printer to print in only black and white by ignore the color ink,for the important document. endliam<>
To Save the color ink you can change the printer settings to Black Only.
To Setup:
  1. Press START Button.
  2. Select RUN Command.
  3. Type these commands in CAPS.
  4. CONTROL PRINTERS and press OK or Enter.
  5. Now you will get Printers & Faxes Window.
  6. There you select the ink jet printer which you want to change the color settings.
  7. Right Click on it and Select Printer Properties later.
  8. Select Printing Preferences
  9. There you can see lot of window tabs (just like a worksheets). Depends on printer in any of the TAB you can see the option Black Only / GrayScale Printing Only.
  10. Choose the appropriate option and Select APPLY.
  11. Then give a test page for it.
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
Dec 31, 2009 | HP DeskJet 3550 InkJet Printer
Deskjet doesn't print real "black"
In the printer preferences, you can choose to print black or color. Check to make sure that when you print, you haven't specified color only.
Apr 30, 2009 | HP DeskJet 3550 InkJet Printer
Colored text printing
The printer assumes that the color cartridge is good, and is trying to print with the dead color cartridge.
See if there is a setting for your printer under the control panel, printer, and go to printer properties.
See if you can select to print BLACK only.
I know they have this option for some Canon Printers, but not sure with the HP Printer Drivers.
Worst case senerio, Highlight all of the text, and change the color to BLACK before printing. You can always just pick up a cheap refilled cartridge at Staples since it wont be used a lot, the quality isnt going to make much difference.
Good luck.
Hope this helps.
Feb 08, 2008 | HP DeskJet 812c InkJet Printer
Printer problem
Check the power cable
Connect the HP Deskjet F4140 All-in-One directly to the walloutlet
Power Cycle:
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
4. Check for the functionality
Reset the All-in-One:
1. Press and hold the Cancel button and then press the Start Copy Color button.
2. Release both buttons. The self-test page prints.
Now check the functionality
Jan 29, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
Ben Johnson
