Question about Lenovo Computers & Internet
My cd room can not play the cd, every time i input the cd, the noise always busy and it can't run
  • 629 Answers
Sounds like a failing CD drive. try to remove and reconnect the drive if you can, update its firmware and use a CD lens cleaner. if this does not work, it would be time to get a new CD or DVD drive. hope this helps. a rating would be appreciated.
Posted on Sep 16, 2010
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
Why my DVDs room player cannot read while it is playing?
buy a CD/DVD lense cleaner...and clean the device...the cleaner looks as CD disk...and it has the cleaner attacehd in that....insert that and run it for some time....
now try play a CD/DVD
Feb 17, 2011 | Sony DW-D22AB : DVD+/-RW 16X Dual Layer...
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
My home theater system plays cds but will not play dvds, what can I do to fix it, makes a scratching noise when i put dvds in it, but plays fine with a cd.
There is something wrong with the DVD drive assembly inside. If you're brave, take it apart and check on what is making the noise. Also, try using a q-tip to clean the laser head if it's accessible.
If that doesn't help, it's time for a new DVD player.
This is why I always recommend people buy a home theater system without a DVD player built in. The DVD player is the weakest link, and stand alone DVD players can be purchased for as little as $25 depending on if you want upconversion or not.
If you cannot get the DVD player working in your surround system, just replace it with a stand alone DVD player, if you can, check to make sure there are audio inputs on the back of the receiver. If there are no audio inputs on the receiver, you will have to get the entire surround system replaced. If so, purchase a separate DVD player and surround system.
Jan 13, 2010 | LG LH-T754 Theater System
I have had my subwoofer for 6 years. It has always
One way to check the operation is to connect a source directly to the inputs of the sub.
A CD player will work fine. Connect the out puts of the CD player to the inputs on the sub. Play a CD.
If you get music from the sub, then no problems with sub.
If nothing, sub has problem.
Could be
A Dead amp.
A Dead speaker.
Velodyne products usually need to be returned to them for service.
Cost is unknown.
Sep 02, 2009 | Velodyne DLS-3500 Subwoofer
White noise in left channel on my Vestax PMC 06 pro-a DJ mixer
try it with nothing plugged in to the inputs, if there is no noise. most likely its the turntable, cd player, or whatever the input is is the problem. or try plugging the mixer into a different area of the house/room. its like if you were to put your cell phone by a mixer, or speakers.
Jun 25, 2009 | Vestax Pmc07pro DJ Mixer System
Compaq presario 700us will play cds wont play dvds
Try to put your laptop always on flat surface. Uneven base gives angle to the already tiny clearance space for the disc. Could be that the DVD disc run coz its finer, it will spin much slower than CD disc.
Hope i give you some good observation.
Mar 29, 2009 | HP Compaq Presario 700, 700A, 700AP,...
Citroen Saxo CD Player will not play when engine running
The car stereo has 2 +12V inputs: the constant batt input and the key in one.
So actually the stereo is always connected to +12V, even in standby.
When you turn your key, the key in input also starts, thus starting your stereo instantly.
When you turn the ignition on, the key in input is switched off for a couple of seconds, so that all the power goes to starting your engine.
After that key in input should be back on - this is your problem here.
One possible solution would be to cut this wire out, and split the RED battery +12V cable so that it enters in the key in input as well. Check wiring diagrams!.
Test this with cables out (without reinstalling the whole thing back in) and if it works.......leave it and put everything back in.
Only downside is, you have to turn off the radio by hand when you exit your car - or you could lose all battery power !
Jan 16, 2009 | Car Audio & Video
CD's sound awful
Try cleaning the lens with a CD lens cleaner. If that doesn't work, the optical pickup may be back. If tht is the case, it can be repaired but it will probably cost quite a bit (more than $100) to repair.
Dec 17, 2007 | Aiwa XR-M131 Shelf System
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
