Question about HP Compaq WF1907 Monitor
Volume control stays on screen - HP Compaq WF1907 Monitor
  • 137 Answers
while the system is turned on,
Remove all cables from monitor.
keep pressing the power button.
reseat the cables.
release the power button.
press the power button again to turn on the monitor.
It must work.
else the monitor needs repair.
Rate this solution and comment to keep in touch or further interaction
Posted on Sep 16, 2010
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
The volume on tv goes up on its own & setting
Its main system control IC is faulty. Its volume control section block[inside the IC] does not control the voltage that adjusts the volume to the TV. In most cases, this IC might have to be replaced. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 20, 2014 | Televison & Video
Volume does not stay level it increases by it stself
This is not a fault with its remote control. The main board to your TV should be checked. Contact any service technician. If you wish to get more details, check the site linked here.
Oct 19, 2014 | Vizio xrt112 smart tv Remote control for...
Cannot lower volume on my sony tv 32L5000
The electronic volume control section circuit is faulty. The system control section tries to adjust the volume, by sending command voltage to the volume control section circuit, but this circuit do not accept or process it. Troubleshooting to this type of fault, is skilled one. Contact any service technician, or the service center.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Timeslide" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Volume icon appears in the middle of my iPad 3 screen and won't stay off.
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
Apr 30, 2014 | Apple iPad 16 GB 3G Tablet PC
Volume stays at 100 i try to turn it down and goes back up
Does this TV have a touch-pad on the TV for the channel/volume/on-off control of the TV? If it does, I would suspect that this board has a problem that is keeping the volume+ function stuck on.
Mar 21, 2014 | Element Televison & Video
I have an 17" (2 in1) n Tru Tech LCD TV (with built in DVD player) The volume can not be adjusted, whether I is the remote or volume control on the TV. It goes to#15 and stays at that volume. What Can I...
I assume "#15" is the displayed volume setting on the screen when you try to adjust the volume. Is this the maximum? If so, perhaps the front panel volume up button is stuck on (not the remote control; nothing else on it would work if that were the case).
Another likely cause is the TV's microcontroller chip or memory chip that goes with it has a fault in its volume control address location.
You can check for a stuck button by comparing its feel with the volume down button when you press it. If it is stuck, the difference in action will probably be noticeable. If you can't tell any difference, the set needs internal repair.
Oct 22, 2010 | Televison & Video
The word volume is staying on the screen and the volume will not stay on. when i go to the start menu it just goes crazy, seems anything i have to use the volume arrows for are not working.
Is it working OK with remote control?
If the problem noticed when you use the front panel buttons, you
have to replace all the tiny switches at a stretch.
Due to contact problem the resistance will vary time to time.
Hence you will get crazy functions. better replace all the button
switches of this type. These are all interlinked.
Sep 03, 2010 | GE Televison & Video
TV stays at the "Please Wait" screen
There is something in the system control not being satified. Probably needs a main PCB.
Oct 13, 2009 | Sharp LC-26D40U 26 in. LCD HDTV
HP Compaq WF1907 Monitor Logo
175 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
