Back to:
PC Laptops
Generic problem for all PC Laptops
No charge
posted by Mistykay on May 17, 2008
The light on power cord lit up, but no charging , no lights on comp at all. HOW can you check if it is a bad motherboard or a crack or the cord???
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 20, 2008
Not Rated (0)
boopar
Rank:Master Master
Rating: 82%, 14 votes
Hi, Use a multimeter to check on the plug to see whether there is voltage coming out from the plug. If so, then it should be your motherboard problem. regards
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No charge:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
HP Pavilion dv1000 PC Notebook
HEllo Can somebody help me I format my pc and i installed...
HP Compaq Evo n610c PC Notebook
hello, when I close the lid and open it later it used to...
HP HP Pavilion dv6000z 15.4" Notebook...
wont power up
PC Laptops
The charger slot on my Amilo Pro v2055 laptop had become...
Toshiba Satellite A305-S6863 15.4" Laptop ...
(I'm not completely sure this is the exact model. Mine...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
