Question about Mitsubishi Televison & Video
I have a LT 46164 and when I try to connect to my wireless router it says wrong password or network problem
kenshin99
  • 89 Answers
SOURCE: wireless router not detected by laptop
Hi!
First, make sure you know the SSID (name of your wireless network) and Network key (if your wireless router is secured). Also, make sure that the SSID broadcast of your laptop is enabled (this is an option in the router if they will broadcast the signal or not).
I assume that your laptop came with a built in Broadcom adapter. Depending on the brand of your laptop, there is always a wireless switch. You need to look for the wireless switch and turn it ON. For most laptops it's a sliding switch on either the side or front of the laptop. For some it's a combination key - like pressing FN + F2 at the same time.
For XP laptops, you can use the XP wireless utility located on the lower right side of your screen like this :
For some reason the XP utility cannot detect any signal and it's telling you that "Windows cannot configure this.. if you enable another utility, use that software to connect", that only means that there is another software in the computer that is running the wireless connection. You can go to Start > All Programs and look for that utility - you can start by searching a program like broadcom.
For Vista , look for this icon to connect:
I hope that helps.
Good luck and have a nice day!
Posted on Oct 02, 2008
Joed911
  • 4338 Answers
SOURCE: I need the network key code in order to access my wireless router
http://192.168.1.1 and press Enter. A logon window appears
like the one shown on the next page.
The Logon screen:
User name: leave blank.
Password: enter the default password admin in all lowercase
letters. (Later on, we recommend changing the default to your
own password for added security using the Password tab of the
following web-based utility.)
Click OK. The Primary Setup screen appears as shown in the
next step.
Go to the security tab. You should see your key there.
Here is the user guide.
http://www.la.viewsonic.com/pdf/userguides/wr100-1_ug_eng.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: I'm trying to connect my DSi to my home network through my router
if your computer can do the internet, the only thing i can suggest as i have limited knowledge is that you get a Nintendo LAN adapter which you plug into your computer when its online and it sends the WiFi signal to the DSi
Posted on Jun 15, 2009
SOURCE: Dynex Wireless Enhanced G Router -- Lost Password
Hi my wireless Dynex is asking me for a password key and I dont remember it? Please adivce on what to do?
Posted on Aug 18, 2009
  • 5 Answers
SOURCE: Connected wireless dongle to LG
Try with same gateway ip & DNS-server ip
Posted on Aug 20, 2010
O14 code
Normally, this happens if you have entered an incorrect wireless password or the signal strength of the network is not that strong. I suggest that you try to relocate the Roku player and make sure to position it facing the router's location.
Double check your router's wireless password.
Jan 03, 2014 | Roku LT
Have hooked up DIR-615. It says the network "dlink" requires a password. Is this predetermined if so how do I find it. I have tried my usuall computer passwords to no avail. Thanks
I assume you're talking about the wireless network, not the wired network.
This password is manually set, not predetermined. To know/change it you'll have to use a network cable to connect to the router instead of wireless.
Once connected, open up your browser to 192.168.0.1, this should bring up the router's web configuration page, from there:
- Login (by default: user: Admin, pw: <blank>
- select WIRELESS SETTINGS and press the "Manual Wireless Network Setup" button
- you should see the configured wireless password at the bottom under the "Wireless Security Mode" section.
if you failed to login with Admin/<blank> combination it means the password is changed previously, in this case, you must reset your router.
Quote from user manual, here's how to reset it:
"To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Good luck
Jun 13, 2012 | D-Link DIR-615 Wireless-N Router (54682G)
How do i set up secured network?
set-secured-wireless-network-netgear-800x800.jpg Set up a Secured Wireless Network on Netgear Photo is inappropriate for this article Submit
A wireless network is comprised of a wireless router, a computer (or other wireless-enabled devices), a high-speed modem, and a subscription to an Internet Service Provider (ISP). Netgear is a popular manufacturer of wireless networking hardware that allows users to set up a secured wireless network. In order to prevent unauthorized users from logging onto your wireless network to gain access the Internet, and in order to protect the data you transmit and receive online, you should change your wireless router's security settings to create a secured wireless network.
1 Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another
2 Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
3 Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
4 Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
5 Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the route
Things You'll Need
* Netgear wireless router
* High-speed Internet service provider (e.g., Comcast, AT&T, Insight)
* Cable/DSL modem
* 2 Ethernet cables
* Computer
* Web browser
* Router address
* Router's username and password
Good Luck : ) ....
Oct 14, 2011 | NetGear WGR614 Wireless Router
Whats a wpa key? I have tried connecting to my router on my wireless device and my wireless device ask's for a wpa key? is it the same as a lan key?
WPA <<===>> WIRELESS PROTECTED ACCESS
You need to use an Ethernet cable to connect a computer to the router, and then access the web-server inside the router, and then run the "Wireless Networking Setup Wizard". When you do, you will set:
* the SSID ("network name") -- pick anything you prefer
* the encryption-level (hint: use 'WPA')
* the password for the network -- pick anything you can remember
Then, from a wireless device, do a "View Available Wireless Networks".
Select the SSID, and enter the password, to make a connection.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
I need to connect a D-Link router to my cable modem so that I can use my laptop anywhere in my home
Cable-modem <-- Ethernet cable --> WAN (or "Internet") port on the router
LAN port on router <-- Ethernet cable --> network-port on your laptop
Then, access the "built-in" web-server on the router,
and run the "Wireless Networking Setup" wizard:
* to set an SSID ("network-name")
* an encryption-level (Hint: choose 'wpa')
* a password for your wireless network
Then, disconnect the Ethernet cable from your computer,
and then "wireless available wireless networks".
Select your newly-created network, and connect to it.
Nov 14, 2010 | Computers & Internet
Hi; We have guests that want to access our home wireless network. When trying to connect to our network........... they see a list of available network and when they select our network it does not ask...
Have you go MAC address filtering enabled, if so you will need to add the MAC address to your wireless router's MAC address table.
It is very difficult to diagnose the problem without knowing your wireless router's configuration and the wireless card configuration in your friend's computer.
The easiest way to give them access is to use a LAN cable, provided you have spare LAN ports on your wireless router.
Aug 09, 2010 | Arris SURFboard SBG900 Wireless Router...
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
Cannot connect laptop to wireless. Apparently my password is wrong (even though I am sure it is not). Have tried to reset wireless router (D-link DI 524) without success.
Make sure that the password that you have is correct if not then you will need to check the password of the wireless network.
Click Here for more info about wireless network.
Oct 08, 2009 | D-Link AirPlusG DI-524UP Wireless Router
How do I reste my password?
hello have you turn the power off and press the reset button on the back of the router press it for 30 seconds good luck
shaun
Feb 05, 2009 | D-Link AirPlus DI-524 Wireless Router
Random wrong passwords
Any router that your connecting to wireless, without a password, does not have wireless security set up on the router.
Any other wireless router that you are trying to connect to that does not allow you to connect wireless, has wireless security set up and that same security must be set up on the wireless device (like laptop or desktop, whatever is not connected via ethernet cable.).
Reply back what you find and I will be glad to help more.
Feb 04, 2009 | Adaptec Computers & Internet
Televison & Video Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
