Question about Kenmore Dryers
Kemore dryer model110.67522600, checked continuity on heating element,OK, Thermal fuse OK,cutoff-tml ? Thermostat #3977767 no continuity.Thermostat #3387134 ?
  • 347 Answers
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Posted on Sep 16, 2010
Kenmore dryer model # 110-60212990 heater element not working. replaced element, thermal fuse, thermal cutoff
Hello
Check high limit thermostat continuity. If ok ,Check for voltage at thermostat side of the heater element.If voltage present timer ok.Most likely centifugal switch at motor.Motor has to be running for element to work.
It's all fixable!
Jul 28, 2011 | Kenmore Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
I cannot afford a service tech right now to come to the house. I hope you can help me through this service. I have a kenmore elite clothes dryer model # 110.63012101 Dryer was not making any heat. ...
you're doing the right thing except for changing out the element without reading it out first.when you check the parts make sure the dryer is unpluged and that you pull at least one of the wires off the part you're checking. check the thermostats on the heater box part
279769 which is part 47,also remove the duct that the lint filter slides into and clean it,if you have a long vent line remove it from the back of the dryer and blow it out with a leaf blower and if you have a shop vac put it on blow and blow off the motor and blow all the lint from the back inside of dryer so it blows to the front and vac it up so you don't have to pull the drum if you don't want to.the thermal cutoff pops when it gets to hot in the dryer most likely from a back up in the vent line or the duct,also go outside and make sure the vent is clear,you should be fine
Sep 29, 2010 | Kenmore Dryers
No heat but already replaced heating elimate
Check the thermal cuttoff. It is located on the element. If it does not have continuity, replace it. Also replace the Hi-limit thermostat, also located on the element, and the operating thermostat, located on the exhaust. These two should cut off the heat before the thermal cutoff blows.
Nov 25, 2009 | Dryers
Replaced elements but does not heat in bowl
Check the thermal cutoff located on the element.  It is designed to blow if the element gets too hot.  If the thermal cutoff is blown, the hi limit thermostat (also located on the element) will also need to be replaced.  It will have two terminals on it and if it is good it will have continuity.  Trace the wires back from the element.  The first one it comes to will be the thermal cutoff, next will be the high limit thermostat.
Nov 07, 2009 | Fisher and Paykel Dryers
Does not heat
heating element is out...there are usually 2.....get em at lowes
Nov 03, 2009 | Kenmore 700 6972 Dryer
Runs, doesn't get hot
Either your element is out our your thermal cutoff.  Check your element for continuity if it is open, replace the element.  If not check the thermal cutoff which is on top of the element.  If the thermal cutoff is open you will also need to replace the operating thermostat and Hi limit thermostat.  The high limit is on the element below the thermal cutoff, and the opperating thermostat is on the exhaust duct.
Oct 25, 2009 | Kenmore Dryers
No Heat - Kenmore Series 90 electric dryer
check cord conections and timer contacts (big wires)
Dec 24, 2008 | Kenmore Dryers
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
301 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
