Question about Watches
I have casio 950 ALT 6000 Watch, It cover Damage & Glass Broken . i want to replace for it can i give a support to me by that parts Thank Roshan ( From Sri Lanka)
2 Suggested Answers
cmcduncand
  • 714 Answers
SOURCE: require a manual for the casio 950 - alt 6000
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 23, 2010
Testimonial: "unfortunately they do not have this manual in pdf format. one can purchase it for $41 on the website: www.2instructions.com.I need a free version."
Glass broken
you can get new glass off ebay
Aug 20, 2013 | Casio ILLUMINATOR DUAL TIME MEN WATCH...
My casio mdv-701 accidently dropped n da glass shattered in the inner part. Service centre does not have the glass for relacement. How can i change the glass for this watch?
In case service center is telling that they don't have glass for your watch then tell them that you are going to approach the HQs of casio and complain regarding this service center that they are not keeping parts for most of the products. This trick works most of the time. Secondly, you can contact any of the local glass experts in your city alongwith your watch. They can measure and cut out a piece of glass for your watch or also you can contact any of local watch maker who can check out if he has any glass piece measuring the same size.
Jun 30, 2011 | Watches
Band of my watch is broken. i like to buy Casio Protrek Triple Sensor PRG80 band can you give me a contact i live in the philippines
You can Contact them at:
63-2-7110288
63-2-7110627
Email address: service@compexinternational.com
Or you can visit any Casio store located in different Malls in Philippines.
Hope this will help you.
Thank you for choosing fixya
Mar 04, 2011 | Casio Protrek Triple Sensor PRG80T7VDR 4 6...
I have a Casio Wave Captor 4757 WVQ-142E and after the change in time this fall I can't seem to set the time correctly. I am in Paris, so GMT +1, however it is 10:30 and my watch reads 3:03. I have reset...
I sympathize, it took me ages to work this out - I had the same problem having had the battery replaced in my watch which only lasted 18 months...the irony was that my previous watch was still working & set to the correct, time date etc!
The following instructions are for the Casio Wave Ceptor 4757 WVQ-142E, the official Casio instructions are available at the following:
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4757
For the extra information Casio neglect to tell you in the manual, read the following:
First, the watch needs resetting. To do this you need a watchmaker's screwdriver, remove the back (4 screws - obviously, you do this at your own risk), remove the thin plastic cover to reveal the battery.
On my watch on the battery cover it says to reset the watch, get a pair of tweezers & connect the battery back to the negative (marked -) plate for about 2 seconds, thus forming a circuit.
The watch stops, the screen goes blank for about 30 seconds, replace the plastic cover , back & screws.
Wait until the watch has picked up the correct time signal, the digital part will show the correct local time, the analogue screen won't at this stage.
Set the watch to the desired time zone that you require or HS (Home Setting).
Then press button "C" (bottom left) to scroll through until "HS" is displayed on the screen, then press button B (top right) for about 5 seconds until it flashes "OO" in the screen, then press the A (top left) button down & to reset the analogue time (so all 3 hands are pointing up) to 12 O'clock, it has to be set to 12 so the watch will recalibrate itself, if it is not set to 12 O'clock, it won't work! - sadly Casio don't tell you this bit in the manual....& of course this is really obvious to us mere mortals!
Now that you have aching hands & repetitive strain injury, press the B button (top left) to exit the (watch) hand setting mode & the watch will now wind the hands by itself to the correct analogue time, (or in theory it will, it took three attempts to set my watch).
Yes, for the record Mr Casio, if you hand a watch to someone & tell them to set it to the correct time, they will set it to the current local time (assuming that it is not 12 O'clock) & as opposed to 12 O'clock by default!
This is not rocket science, if your company is able to make & market a radio controlled watch which is in theory accurate to one second in a million years because it is controlled by the Rugby atomic clock, you'd think that the instruction department could write some decent instructions!
Hopefully this solved the problem!
Nov 02, 2010 | Watches
My watch glass is broken how much will it cost to get a new glass
mcdevito75 Here, Look for a small watch repair shop in your area for the new crystal (glass) for your casio watch, approx. cost with labor, $75.00----4125.00
Sep 13, 2010 | Casio AW80-1AV Wrist Watch
I have a sector urban oversize watch 3H case diameter 4.8mm with a broken watch glass crystal.I would like you to inform me of the replacement glass diameter and thickness i should choose to fit the...
I cant inform about the exact size of the watch glass by the model or number of the case. For that you need to use micrometer to measure the thickness and diameter of glass. Most sommon thickness is 1mm. If the glass is broke, measure the thickness of any broken leftover and then the diameter by puting the calliper arms into watches groove for glass.
Aug 26, 2010 | Watches
Require a manual for the casio 950 - alt 6000 watch. need to know how to set the temperature setting to Celcius
Hope this tip helps
R/
David
Feb 23, 2010 | Casio Watches
Light button cover - finding part
Sorry we do not have parts here or any means to locate them.
Sep 10, 2017 | Casio PRG60T-7 Wrist Watch
Casio broken
The band must be replaced, that part is not replaceable. Sorry.
Dec 05, 2007 | Casio AWS90D-2AV Wrist Watch
Watches Logo
201 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
