Question about HP Deskjet F340 All-In-One Printer
WHAT DO YOU MEAN BY ALL IN ONE PRINTER? - HP Deskjet F340 All-In-One Printer
  • HP Master
  • 629 Answers
These type of printers can also be used for scanning an copying documents in addition to printing files. This way, you do not need to get a separate scanner device/machine and a copier. You get all 3 features in one device thus all -in - one. hope this clears it up.
Posted on Sep 16, 2010
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
10.1001 supply memory error
Hi Dang,
A supply memory error can mean a couple of things. The first thing is that the supplies are not correctly seated/installed. Turn the printer off and reseat/install all of the supplies. Turn the printer back on and see if the error clears. It can also mean you are using compatible cartridges. If that is the case usually pressing the green "check mark" button will allow the printer to continue. It can also mean that one of your cartridges is bad or the sensor in the machine is bad (although this is rare).
In case Still Having Problem Then Follow Us For Hp Printer Problems For On :
HP Printer Support
Feb 06, 2014 | HP Laserjet Cp2025n Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
The printer does not work. I have 2 errors that show up on the printer. they read: TFFS0 ERROR 01 TFFS1 ERROR 02 what do these errors mean? how can I get rid of them?
The printer does not work. I have 2 errors that show up on the printer. they read:TFFS0 ERROR 01TFFS1 ERROR 02what do these errors mean? how can I get rid of them?
May 17, 2010 | Xerox Phaser 6120N Printer
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
Error 0x88106158
This mean fatal error.Buy new printer.
Jan 08, 2010 | HP PSC 2355 All-In-One InkJet Printer
Printer is printing double
Define "double".
Do you mean "bold" fonts, rather than "regular" fonts?
Do you mean not "advancing" the paper, line-by-line, and "overprinting"?
Do you mean "double-sided", rather than "single-sided" ?
Nov 29, 2009 | HP PSC 1510 All-In-One InkJet Printer
Lexmark 617 is failing communication with the computer
Please, I need a lot more help from you. What do you mean by "Failing communication"? Do you mean that when you attach the printer to the PC, the PC fails to see the printer? Try this, disconnect the printer from the PC. Using the Maintenance Utilities on the printer, print out a demo or a test page. This way we can establish whether or not the printer is functioning properly. If it worksw, connect the PC to the Printer and use the driver to send a test page to the printer. Please let me know if you still have a failure. By the way, I know this is a silly question and I don't mean to insult you, but are you sure the printer is plugged into a fully functioning power source? :) Don
Jun 11, 2009 | Lexmark International Z615;...
PRINTER FAULT
Hi, im guessing what you mean lol. if you mean its printing lots of symbols etc all over the page you should uninstall the printer, and reinstall the printer and check cable are pushed in right, usually fixes this fault..
Happy New Year
John
Dec 17, 2007 | Epson Stylus Color 740 InkJet Printer
mukhtar21 shaikh
mukhtar21 shaikh
