Question about HP PSC 1410 All-In-One InkJet Printer
Put new ink cartridges in printer and still says "check print cartridge" and "check paper"
  • 137 Answers
hope you bought correct and branded cardridge.
follow the steps:
1. Remove the cables.
2. Press power button for 3 mins.
3. turn off /shutdown everything that was connected.
4. Reseat the cables. make sure these are intact.
5. boot up/power on (if computer is connected. boot up computer first.)
6. turn on the printer.
your printer shall not give the ugly messages any more.
Rate this solution and write a comment to keep in touch.
- WizBee
Posted on Sep 16, 2010
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Just put 2 new ink cartridges in my printer - black and tricolor. the printer receives the message to print, sends the paper through and sounds like it is printing, but then the paper is blank with no ink...
Hi
Just remove the new 2 cartridges and rub the print head in a plain paper with isopropyl alcohol until ink flows, and then return the ink cartridges and run the print nozzle for 2-3 times. After that, try to print again.
Please let me know if you need more help.
Mar 05, 2011 | HP OfficeJet D135 All-In-One InkJet...
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Print is Smudged
you may try
1) clean the cartridge nozzles with dry soft paper
2) clean the cartridge carriage down side surface there might be bled ink.
3) check the cartridge up side there is the lable cover the ink refill hole is ok, no any lable stick there you need put stick lable there.
Nov 12, 2008 | HP PSC 1600 InkJet Printer
Pulls paper through, but doesn't actually print anything on the paper
check to see if the cartridges are in all of the way. because it may not have punctured the ink seal...
Jul 10, 2008 | HP Deskjet D4160 InkJet Photo Printer
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
100 people viewed this question
Seeker5211
Seeker5211
