Question about Clarke Power Products Air Compressor Regulator W Gauge Clarke
Clarke air compressor model #ac20018 Runs but
Clarke air compressor model #ac20018 Runs but doesn't produce any air. Not too old, kept indoors. Last used a couple of months ago.
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
Looking for parts for a Clarke air compressor,model AC2002
try going through machine mart in uk they are main agents for clarke machines
Jul 05, 2012 | Clarke Air Tools & Compressors
try machine mart in uk they are main agents for clarke machines over here
Jul 06, 2012 | Clarke Air Tools & Compressors
I have the clark 4 gallon compressor Model #AC2001B. When I pull the on switch the compressure attempts to start. It runs slowly for a few seconds then stops. I do not know why this occurs. Thanks
Hi I know these need to be very high powered so try plugging it in direct to the mains not an extension lead or use the mains from the house not a garage or outhouse hope this works!
Jun 22, 2011 | Clarke Power Products Inc AC2001 2HP 4...
I have a Clarke SHHH air 2/9 compressor
Hi
Can you hear any leakage, if not then I would suspect a valve is jammed open.
Gently tap valve housing with a soft hammer, may dislodge the valve.
Aug 11, 2009 | Clarke Air Tools & Compressors
Clarke Power Products Air Compressor Regulator W Gauge Clarke Logo
107 people viewed this question
Top Clarke Power Products Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Clarke Power Products Air Tool and Compressor Expert? Answer questions, earn points and help others
