Question about Compaq Presario 700 470024-192 Notebook
My compaq sound is not coming from internal speaker but it is coming from headphones,
  • Compaq Master
  • 629 Answers
Check your audio settings to make sure the speakers are set to laptop speakers, verify that the volume for the internal speakers are set to high and not muted. if this does not work, time to get replacements for your internal speakers. hope this helps and your rating would be appreciated,
Posted on Sep 16, 2010
    President:
  • 2,291 Answers
Check ur hardware, put the half pin of headphone to the port and check for sound in internal speaker , download registry cleaner reg in out may help u
  • 137 Answers
Its a pure Hareware issue.
get this fixed.
avoid doing it by tourself .
it has got tiny parts and crisp cables.
  • 71 Answers
SOURCE: internal speaker problem
connection frayed
um haard 2 fix if u want i can give u a step by step how 2 fix
just contact me at femi.amoo@gmail.com
Posted on Jul 30, 2008
  • 3940 Answers
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Posted on Mar 02, 2009
  • 788 Answers
SOURCE: Mic not working and audio coming from both headphone and internal speaker of laptop
Before you go changing drivers and re-installing.
Are you useing the Headphone set supplied by HP on the Laptop ?
The Male jack may fit your input connection but be the wrong connection configuration.
Just an idea. Try a regular mic and make sure it works before making all kinds of changes.
If the headphone set was supplied by HP with your unit, then you may want to bring it buy Radio Shack and ask them to check it for you.
A short in the input wiring will mess things up.
Hope this helps.
Posted on Jul 27, 2009
MPetro302
  • 298 Answers
SOURCE: Speakers won't work on my compaq presario v3000, HELP!!!
right click and choose unmute.
Posted on Aug 10, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Hi,
I assume you tried other headphones and I also assume you tried all the 3.5mm jacks, just to be sure. Assuming this is true, then the headphone jack itself is the issue. make sure the plug goes ALL the way in. if it sticks out by just a few millimeters, then that means there is something stuck in the hole itself, and not allowing the jack to work.
Posted on Aug 31, 2009
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
moz-screenshot.pngmoz-screenshot-1.pngYour front panel audio / microphone connector has an AC97 connector inside which looks like this:
http://www.digitaldingus.com/reviews/silverstone/fp34/fp34-usb-ac97.jpg
It is probably plugged into the motherboard somewhere. Try plugging it into the soundcard directly if it is in the motherboard. Or vice versa if it is plugged into the soundcard.
-Alex
May 06, 2011 | Computers & Internet
I am not getting any sound out of my internal speakers iam getting sound from my headphones
Make sure your sound is not muted for one.
Next, unplug your headphones, if the sound is still not working threw your internal speakers. Check to see if they are on or even installed correctly.
(For Windows 7) But if you have any other OS, just find the Sound from your Control panel.
Start, Control Panel, Hardware and Sound, Sound, Playback TAB. Make sure your "speakers" are "enabled" and "set to default".
May 21, 2010 | HP Compaq 6720s PC Notebook
No sound from built in speakers but headphones work
Have you checked the speaker settings? Make sure that all settings are NOT muted. One selection that is muted maybe where the sound is generated from. Such as MIDI playback. Otherwise it has to be either a missing update/driver or damaged speakers.
Oct 06, 2009 | Compaq Presario Notebook
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Sound is working but internal speaker is not working
Mar 01, 2009 | Dell Latitude D410 Notebook
Sound Coming From BOTH SPEAKErs and headphones
Sound emanating from both the internal speakers and headphone/earphone while the later is engaged could mean a factory defect in your speaker device. Upgrading your OS from XP to Vista may not solve your problem. However, since the service center technician will probably insist on his diagnosis and recommendation, you may need to upgrade your OS just to prove your point.
Jan 25, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
My sound is not working unless i use headphones.
You need to check if internal speakers connection / cable is hooked up properly. You may need to open up the pc to see. If help needed on this, please as a technician to assist if you're not comfortable enough in opening it up alll by yourself.
If the connection or the internal speakers is busted, parts may need replacement.
Jan 06, 2009 | HP Compaq Presario CQ50-211NR Notebook
My internal speakers have sound when headphones are used but no sound when they are used without headphones
my frnd the internal speaker will have sound by default it comes from dos...When it comes for headphones or speakers u have to install the sound drivers which comes from pc.....install it it will work...
May 20, 2008 | Gateway Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
119 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
