Question about Whirlpool Refrigerators
Ice maker no longer makes ice - Whirlpool Refrigerators
    Guru:
  • 93 Answers
That could be caused by a number of things. Freezer temperature is too high, The Tube that feeds water into the icemaker could be froze up. Bad Water Valve. or Bad IceMaker.
Ensure the the Bar on the side of the icemaker can go completely down, against the side of the icemaker.
Let me know how you make out.
Bill
Posted on May 17, 2008
  • 489 Answers
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Posted on May 11, 2008
SOURCE: GE GSS25LGM Ice maker
Our Ice maker quit working. Won't make ice, but will dispense water. I unplugged the refrigerator and plugged it back in. I noticed that the green light on the ice maker is now blinking. It was steady on before I unplugged the fridge. Any ideas?
Posted on Feb 12, 2008
SOURCE: Ice maker not working but are getting water from dispenser.
IF YOU HAVE THE SAME FREEZER AS MY MOM HAS THEN I MAY CAN HELP YOU OUT. FIRST OFF WHEN YOU OPEN THE FREEZER PORTION (SIDE BY SIDE STYLE) YOU WILL SEE THE ICE DISPENSER. TAKE THE PART OFF WHERE IS SHOWS YOU: TO MAKE ICE MAKE SURE ARM IS DOWN AND TO STOP MAKING ICE RAISE ARM. THAT IS A COVER THAT WILL COME OFF WITH NO TOOLS NEEDED. ONCE YOU OPEN THIS YOU WILL SEE A METAL FRAME WITH A WHEEL IN THE MIDDLE THAT SAYS DO NOT TURN BY HAND. LOOK IN THE MIDDLE OF THE WHEEL AND SEE IF THE ROD IS BROKEN (FOR EXAMPLE MY MOMS HAD A CLIP ON THE ROD THAT WAS BROKE AND WOULD NOT ALLOW THE DIAL TO SPIN WHICH THEN MAKES THE ICE MACHINE SCOOP THE ICE OUT OF THE BOX) CHECK THIS WHEEL TO SEE IF IT IS STILL IN TACT. THIS COULD BE YOUR PROBLEM.
Posted on Mar 18, 2009
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
  • 112 Answers
SOURCE: ice maker no longer makes ice; water still comes
THE WATER VALVE IN THE BACK IS A TWO PART SYSTEM. EVEN THOUGH YOU GET WATER FROM THE DOOR THE ICE MAKER SIDE OF THE VALVE COULD BE BAD. CHANGE VALVE. B4 YOU SPEND THAT KINDA MONEY--DO A SELF CHECK FIRST--POUR WATER IN THE ICE CUBE TRAY. IF IT FREEZES AND DUMPS THEN CHANGE THEWATER VALVE. IF IT FREEZES BUT DONT DUMP CHANGE THE ICE MAKER.
Posted on Mar 16, 2010
Not enought water to ice maker
Can you provide a make & model # for the unit?
Feb 08, 2014 | Refrigerators
My Whynter UIM-155 ice maker used to make alot of ice quickly. Now, it does not make very much ice and it takes a long time? What should I do?
look at the condenser coli to see if it is dirty if so clean it. Dirty coil will cause it longer to make ice. also make sure nothing is blocking the condenser return.
Aug 20, 2013 | Whynter UIM-155 Stainless Steel Built-In...
Our Marvel icemaker was working great then it starting making ice at a much slower pace. It is not make ice no where near as fast as it was. What could be the problem?
Could be a dirty condenser coil, blocked return air, if the ice machine is in a warm environment it takes longer to make ice, water temperature if it is warmer it will take longer to make ice. if water inlet valve is letting water seep buy during freeze cycle it will take longer to freeze.
Dec 17, 2012 | Marvel Appliance Ice Maker
My whirlpool ed5phexrb00 icemaker no longer works
Ice maker does not seem to have water flowing to it.
Mar 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker doen't make as much ice as before in the ice dispen
level the refrigerator. water pressure may be too high 65 psi max. check if there is a chunk of ice stuck, diverting the influx of water, cubes should not exceed 7/8 in thick or tall at widest point. no axel mark on top. fill should be no longer than 7.5 seconds.If longer then 7.5 sec, replace modual
Aug 24, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The ice machine is no longer taking in water to make ice
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
Mar 13, 2009 | Refrigerators
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
LG Ice maker
Apr 20, 2008 | LG LRSC-26930 Side by Side Refrigerator
No ice
see if there is a device the water goes into then another tubes come out and goes to the ice maker, that middle part is bad.
Feb 06, 2008 | Estate TS25AFXK Side by Side Refrigerator
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
