Question about Kitchen Ranges
My brand new GE Profile gas range produces a black soothe. All my pots are covered with in black. How do I fix this problem
  • Kitchen Ranges Master
  • 3,740 Answers
Hi. Usually when this occurs on a brand new unit the user is using a natural gas configured range on LPG. You may have to get a NG to LPG conversion kit to reconfigure the regulator. On most newer regulators it is a matter of unswcreing the plastic side cap and flipping the inner plunger over. The conversion process is in the installation instructions. Additionally the Bake and Broil burners for the oven will also need adjusted per instructions. There are usually orifices in a package in a NEW range for the conversion of the cook top burner control valves. Then the air gap on the side of each burner gas tube will need to be adjusted by losening the screw on the side of the burner gas tube and adjusting the airflow until you get a nice 2 color blue flame. Tighten the screws after you make the air adjustment.
If you do NOT have the manual please respond with a model number so I can try and find you one.
Thanks for choosing FixYa,
Kelly
Posted on Sep 16, 2010
The oven cooks 25 to 40 degrees lower than what it is set for.
Are you hooked up to city gas or LP(tank outside ur house), u might need to change some hookups to accomidate, when u use ur range, does it turn the bottom of your pots black?
Feb 22, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Good morning, I bought a 30" slide in range and
daweoo washing machine when start the digital screen shown E9 did not machine start
Jan 07, 2011 | GE Profile 30" Slide-In Gas Range -...
My ge profile range top and burner work bu the
try cleaning the ignition wire (spark) it works with ground
Nov 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Yellow flame blackening pots and oven
Are you on LP/Propane gas or Natural gas?
Was the range set up by a technician?
Mar 13, 2009 | GE Kitchen Ranges
Burner won't light
Take the pot support and the burner cover off and clean all the slots out with a toothpick. Carbon builds up over time and the gas doesn't flow over the spark. Do not light until fully reassembled.
Feb 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean...
There is usually a "shutter door" adjustment at the end of the burner to control the amount of air that is mixed with the gas. If you just did a conversion the air fuel mixture likely needs adjustment. You want a blue flame with faint yellow tips or optimal adjustment. Too little air causes soot and too much air is noisy and wastes fuel. Remove the burner (as for cleaning) and open the shutter door on it, replace, and retry until the correct burn is achieved. I don't have direct answer for the Kenmore. Did you try using the model number in Google or Ask? If you don't get a hit the call Sears Service and request a manual.
Jan 16, 2009 | Kitchen Ranges
My new gas stove (propane) is releasing black soothe when lit. All the pots are covered in this black powdery like substance. Whats the problem and how can i fix it. It's really costing me a lot to clean .
All gas stoves are set up for natural gas. Before using on propane, the oven and burners need to be converted for propane operation. Refer to the installation manual for conversion requirements for your particular stove.
Dec 25, 2008 | Kitchen Ranges
GE Profile JGSP32GEV3BB slide in range - regulator went bad #WB19K5020
"GE makes garbage" that's what a lot of independent servicers says about brands they can't become authorized to work on because GE for instance has factory service. What makes the repairman think the regulator is bad? It is highly unlikely to be the case.
May 12, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile gas range jgb908sel3ss
most doors lift right off their hinges when the door is opened about 6 inches. A few have screws on the inside which have to be removed before you pull the door off.
Mar 04, 2008 | GE Profile Spectra JGB920SECSS Gas Kitchen...
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
180 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
