Question about Healthometer Health o meter Digital Lithium Hdm753dq 95 (Health O Meter)
HDM753DQ-95; The scale is no longer displaying reading, it is flashing a very faint purple light. Ireplaced the battery and it still does the same.
A foot may be bad. I am trying to get a replacement as mine fell off after having the same problem for several weeks.
Posted on Nov 26, 2010
I have a Salter 9007 bathroom scale. It stopped working so I bought replacement lithium batteries and installed them
Do you still have the manual with the troubleshooting section in it? It looks like this is an overload condiiton or an indicator that something is not right. The manual can help you to sort this out.
Mar 01, 2017 | Salter Health & Beauty
Replaced three batteries in polder kitchen scale, now it just flashes light. Can't turn on or off and no digital readings
Be sure all 3 batteries are fresh and also be sure they are in correctly .positive+ and negative- , to proper placement in machine. Typically the spring contact points go on the flat -end of battery and the + nipple end of battery goes on the solid or button contact on the machine. Spring end contact points on machine may be an actual spring or a raised metal piece either way they are the end that flexes and holds the battery tight against both contact points. Sometimes the spring must be carefully pulled to make it give more holding pressure. Good luck and I always say Google it!
Oct 18, 2017 | Polder KSC-310-28 Easy-Read Digital...
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Display is faint and to light to read
Turn the calculator on. Hold down the "C" key (just above the ON key) and press + to darken the screen. If you go too far, use the C and - keys to lighten the screen.
Jan 21, 2012 | HP 10b Calculator
My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
My 2003 grand am's emergency flasher is clicking intermittantly and sporadically without being turned on. have replaced the flasher hazard switch/module, but it didn't fix the problem.
Hello! The Hazard Switch/Module connector has the following wires of interest...Pin G=Dark Blue (right side lights)...Pin F=Light Blue/Black (left side lights)...Pin H= Purple (flasher battery)...And Pin A=Black (ground)...In order for the lights to flash, without pressing the switch, Flasher Battery must be applied to Pins G and/or F...When the problem occurs are all external lights flashing or just one side? Visually inspect the connector for bent pins and the harness for bare or frayed wires...If you have a multimeter and a wee bit of experience using it; Set the ohm meter to X10 scale...Measure from Pin A (black wire) to the center of the negative battery post...Reading should be zero ohms or very close to it...Send results...
Guru.......saailer
Nov 20, 2010 | 2003 Pontiac Grand Am
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Healthometer Health o meter Digital Lithium Hdm753dq 95 (Health O Meter) Logo
627 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
