Question about Caterpillar American Construction Equipment 1:87 Scale
I have the sign on my Cat "Incorrect ECS switch inputs"
I always sign in with rackergrp@aol.com and I have never changed my password and I cannot get in
Could be virus or keyboard is inputting caps at the beginning.best solution is to try sign on and somewhere there on the login screen will be a forgot password link which will get aol to send an email with a link to reset the password.
Jan 24, 2015 | Computers & Internet
2004 nissan xterra run great for 12 miles then misfiring,cnt get over 45 miles an hour. codes p 0733,p0420,p0430,p0328 comes up. new wires,new cap,rotor spark plugs 6 months old timming belt 6 months...
code p0733 refers to gear 3 -incorrect ration===causes---wiring---TR sensor/switch--shift solenoids---transmission mechanical fault
code p0420 refers to catalytic converter system -bank 1---efficiency below threshold===causes--cat converter--wiring--HO2s 2
code po430 refers to cat converter system bank 2--efficiency below threshold===causes--cat converter--wiring ---HO2s 2
code p0328 refers to knock sensor (KS) 1 bank 1--high input===causes--wiring short to positive--KS incorrectly tightened--KS---ECM
basically replace the cat converters as they are blocking the exhaust system and preventing your over 45mph problem
replace the TR sensor/ switch as you have not mentioned a transmission problem
Rectify the problem with the KS as it controls the air/fuel mixture setting which contributes to the car getting hot.
Jan 12, 2014 | Nissan Cars & Trucks
I need help asap 2003 Expedition code p0171 and code p0712 i have and idea of the 1st code but whats the secound code i really need help i dont want to take it to a shop where there going to charge me alot...
P0700 Transmission Control System
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System -Electrical
P0703 Torque Converter/Brake Switch B Circuit
P0704 Clutch Pedal Position Switch -Circuit Malfunction
P0705 Transmission Range Sensor/Switch Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor/Switch Circuit Range/Performance
P0707 Transmission Range Sensor/Switch Circuit Low Input
P0708 Transmission Range Sensor/Switch Circuit High Input
P0709 Transmission Range Sensor/Switch Circuit intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit
P0721 Output Shaft Speed Sensor Circuit Range/Performance
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine RPM Input Circuit
P0726 Engine RPM Input Circuit Range/Performance
P0727 Engine RPM Input Circuit No Signal
P0728 Engine RPM Input Circuit Intermittent
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Solenoid Circuit
P0741 Torque Converter Clutch Solenoid Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Solenoid Circuit Stuck On
P0743 Torque Converter Clutch Solenoid Circuit Electrical
Now i dont know a lot about automatics especially modern ones with all this fancy electronics thats used nowdays but i think its a fault with the temperature sensor for the gearbox.But where its located and what it looks like i have no idea it could even be mounted inside the gearbox .Sorry not a very good answer from a mechanic but?? very few of our europeon cars come with auto transmission .Evan when i do know whats wrong i cannot buy the parts for the gearbox as only re-con boxes supplied by the dealer so best advice is to try a specialist in auto box repairs only .PS some of my best students when i used to teach mechanics many moons ago were the girls so no excuses like iam only a girl please
Apr 22, 2013 | Cars & Trucks
My c6 in bronco starts off in 2nd gear performs ok every other way.
P0700 Transm.Contr.System Malfunction 17084
P0702 Transm.Contr.System Electrical 17086
P0703 Torque Converter/Brake Switch B Circ Malfunction 17087
P0705 Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction 17089
P0706 Transm.Range Sensor Circ Range/Performance 17090
P0707 Transm.Range Sensor Circ Low Input 17091
P0708 Transm.Range Sensor Circ High Input 17092
P0710 Transm.Fluid Temp.Sensor Circ. Malfunction 17094
P0711 Transm.Fluid Temp.Sensor Circ. Range/Performance 17095
P0712 Transm.Fluid Temp.Sensor Circ. Low Input 17096
P0713 Transm.Fluid Temp.Sensor Circ. High Input 17097
P0715 Input Turbine/Speed Sensor Circ. Malfunction 17099
P0716 Input Turbine/Speed Sensor Circ. Range/Performance 17100
P0717 Input Turbine/Speed Sensor Circ. No Signal 17101
P0721 Output Speed Sensor Circ Range/Performance 17105
P0722 Output Speed Sensor Circ No Signal 17106
P0725 Engine Speed Inp.Circ. Malfunction 17109
P0726 Engine Speed Inp.Circ. Range/Performance 17110
P0727 Engine Speed Inp.Circ. No Signal 17111
P0730 Gear Incorrect Ratio 17114
P0731 Gear 1 Incorrect Ratio 17115
P0732 Gear 2 Incorrect Ratio 17116
P0733 Gear 3 Incorrect Ratio 17117
P0734 Gear 4 Incorrect Ratio 17118
P0735 Gear 5 Incorrect Ratio 17119
P0740 Torque Converter Clutch Circ Malfunction 17124
P0741 Torque Converter Clutch Circ Performance or Stuck Off 17125
P0748 Pressure Contr.Solenoid Electrical 17132
P0750 Shift Solenoid A malfunction 17134
P0751 Shift Solenoid A Performance or Stuck Off 17135
P0752 Shift Solenoid A Stuck On 17136
P0753 Shift Solenoid A Electrical 17137
P0756 Shift Solenoid B Performance or Stuck Off 17140
P0757 Shift Solenoid B Stuck On 17141
P0758 Shift Solenoid B Electrical 17142
P0761 Shift Solenoid C Performance or Stuck Off 17145
P0762 Shift Solenoid C Stuck On 17146
P0763 Shift Solenoid C Electrical 17147
P0768 Shift Solenoid D Electrical 17152
P0773 Shift Solenoid E Electrical 17157
P0790 Normal/Performance Switch Circ Malfunction 17174
Dec 20, 2010 | 1985 Ford Bronco
Hi sir, i want some details related to the gear
Dec 20, 2010 | 2006 Renault Fuego
Some of the keys not working such as the pound sign# and the @ sign i have to use the number 2 to activate the @ sign
Your PC Language settings are incorrect
How to change keyboard language in Windows
Instructions for Windows Vista
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
  2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
  3. Open Regional and Language Options.
  4. Click on the Languages tab.
  5. Under Text services and input languages, click on the Details button.
  7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
  8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
Jul 02, 2010 | Dell 0Y3740 Keyboard
I have nuvo 4 zone switch that I cannot get to
That indicated there is a short or incorrect wiring on the combus of the keypads.
Remove the keypads from the walls and unplug them one at a time.
Then unplug one at a time from the all-port until it works.
The last one you unplug will be the offender, inspect the cat-5 crimp for a pair or wires that are in the incorrect order.
Cheers!
Jul 19, 2009 | Nuvo Simplese D 4-Source 4-Zone Audio...
Is there a problem with my engine
E = error. Have dealer run scan test for fault codes.
Electronic Transmission Error Indicator
The vehicle is equipped with a redundant electronic gearshift indicator. This character appears with the key in the RUN position and displays the same gear selection as shown on the selector lever floor console next to the range selector lever. If an "E" character flashes or remains on this indicates that a transmission malfunction has occurred.
Visual Inspection Chart Mechanical Electrical
  • Shift lock actuator
  • Transmission control switch
  • SST (+/-) switches
  • Shift cable and bracket
  • Park sense switch
  • Central junction box (CJB) Fuse:
    • 204 (5A)
    • 205 (5A)
  • Damaged wiring harness
  • Loose or corroded connections
  • Powertrain control module (PCM)
Diagnostic Trouble Code Chart Five Digit DTC Component Description Condition Symptom Action P0815 SST +/- SST +/- circuit input signal failed. PCM has detected an incorrect voltage SST input. May not be able to shift in manual mode. Go To Pinpoint Test C . P1780 TCS TCS input incorrect per selected position. TCS voltage incorrect. No overdrive cancel when range selector is moved. Go To Pinpoint Test A .
Apr 24, 2009 | 2001 Lincoln LS
ECS 755-A2 USB 2.0 no working
The best thing to do is uninstall the USB drivers on the machine and download off ECS the latest firmware and install.
Jan 07, 2009 | EliteGroup ECS 755-A2 Motherboard
Caterpillar American Construction Equipment 1:87 Scale Logo
237 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Ted Maxwell
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
