Question about KitchenAid Dishwashers
Soap is not draining and is leaking onto the floor
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Hi, thanks for using FixYa.com! Sounds like maybe a sudsing issue! If this is the case, put about 1/2 cup vegetable oil in tub and run for a minute or two. Try canceling out after oil has taken care of the bubbles!
Posted on Sep 16, 2010
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Oct 07, 2015 | Refrigerators
Refrigerator leaks onto floor?
when fridge goes into deffrost water from defrosted ice should drain to underneath fridge. drain could be clogged.... or ice has buily up over drain hole.
Sep 01, 2014 | Refrigerators
Electrolux front load washer leaking bleach onto floor
may be u use diff soap? check ur soap if is for front load or top load?
if soap is correct but still leak its means the hose or tub is have crack and coz of leaking.
call the technician for your safety and not to waste money.
Oct 31, 2013 | Electrolux EWFLW65HIW Front Load Washer...
I have to put a towel on the floor under the dishwasher because the water is flowing out of the bottom. We have cleaned the drain. Any suggestions? Could it be the gasket on the bottom of the door?
If the water is leaking from the door then it is usually
the corner door seals,worn or missing, if the water is leaking
out the bottom, then it is the pump itself. Inspect the pump visually for soap tracks
down the metal assembly holding the solenoid which controls the drain valve.
There will also be obvious water spots and even soap buildup on the floor and
it will drip during draining. Pumps are rather pricey, and sometimes approach
the cost of a new contractor grade unit. Hope it is just the door seals.
Apr 04, 2011 | Dishwashers
My dishwasher was pouring out suds onto our floor, why?
useing to much dw soap can cause it to fill it then drain it and again and again till its all gone
May 31, 2010 | GE Nautilus 24" Built-in Dishwasher
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
So water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Jan 27, 2009 | Refrigerators
Soap leaking out of the bottom of washer
highly likely if you didn't use your shipping bolts when moving your tub cracked bottom of soap dispenser inside of washer buy warrnnty sear about 250.00."less soap plz"
Nov 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
42 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
