Question about GE Energy Star WCVH6260F Front Load Washer
Washer stops and start button blinks
Every time i run my washer it stops mid cycle and start stop butoon blinks, washer will not start untill i push the button again. seems to be having most trouble drainning out i hear the pump motor but water trickles out. wondering if something is dammaged?
  • 1 more comment
  • daddyosgrl May 22, 2008
    I have the same problem! I have been researching and the pump filter may need to be cleaned but I have no idea how to get to it. Anyone?
  • ferdmac May 25, 2008
    Mine is also doing the same thing. How do I access the filter and what tools do I need?
  • cfg12 May 11, 2010
    Whats an impeller and where is it located. My problem is it won't agitate or spin-maybe impeller? The drain is clear. Thanks!
The solution is pretty simple. there is a filter located right before the water pump.
* Remove the lower panel (lower as if you were looking at the front of the machine)
* Remove the 3 screws (it is easy if you have the lower drawer unit .. you will have to 'get low' if you don;t have it)
* You will see a 3" cap right facing you (in the center)
* GET A POT. and place it below the cap (foul water will come out when you remove the cap)
* remove the cap (finger tight)
* I found coins, hair, lint, dollar bills .. etc (about the size of a roll of cookie dough)
* Take CLEAN water and dump it into the washing machine (this will clean out the tube/hose)
* replace cap
* run machine BEFORE you put the cover back on (make sure it doesn;t leak)
* replace cover/screws
Posted on Jul 09, 2008
  • 975 Answers
It could be something stuck inside the DRAIN MOTOR PUMP , need to take it out , do some cleaning , remove anything thats inside the impellers , and give it another try , AJ
Posted on May 17, 2008
Solution #2 worked like a charm!!!
great descriptions/step-by-step guide!
my only difficulty was getting the cover screws back on. yippy!
Posted on Aug 13, 2008
Thank you johnfromiowa!
I followed your directions and found my girlfriend's watch she hasn't seen in a year! There was almost enough change in there to pay for a service call as well as the typical lint, etc.
It is working wonderfully and we are off to dinner with the spare change and money saved from a repair bill.
Posted on Aug 05, 2008
Thank you guys you saved me a bundle, i am not a mechanic , never worked on anything but your tips helped me.
Posted on Jul 02, 2008
Thank you!!! Mine is doing the same thing, but I really don't understand Julianfix response. How do I get to the drain motor pump?
  • adamsfmly May 24, 2008
    Thank you Julianfix. I found the filter under the washer. Works like it is brand new again. My water was not draining and my clothes were starting to stink, bad!!!! There was a ton of junk in it. (hair rubber bands, bracelet, lots of lint, etc) Took mabe 15 min and saved us $$$. Thanks!
  • William Dovey
    William Dovey Sep 03, 2012
    well this should be done once every 8 to 10 months or if you notice clothes are not comming out way to wet
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
see this causes and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 25, 2012 | Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it. watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stopped working in mid cycle
lid switch assemblie.its the part where if you open the washer lid all stops,its that may buy it on line with you model and ser# or at a local appliance store. God bless ,tom
Jan 30, 2009 | Maytag Atlantis MAV6000 Top Load Washer
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
GE Energy Star WCVH6260F Front Load Washer Logo
235 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
