Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-S5087W 56" Confused...
Hello. I recently got hit with the three LED indicator lights, telling me the lamp was bad and needed replacement. I contacted Dicount Merchant to order a replacement lamp + enclosure. Installed the new lamp/enclosure correctly. Made sure the cover was sucure. Turned the TV on everything appeared to work great. I used the television for nearly two hours with no problem and went to bed. The next day, I went to turn the television on and I got the green indicator light flashing "lamp". It cycled approximatley three times, then went to flashing all three LED indicator lights. Which the manual calls for replacement of lamp...? What are the chances of getting a bad lamp? Also, are there any indicator signs that would point to a ballast problem or DMD board? Thanks guys for what ever input you may be able to give! I have the same problem on a HLN5065W and can't seem to make it work.
  • 2,326 Answers
I would suggest to remove the lamp again and visual check the filament or you can also use a multimeter and check for continuity or low resistance. If you have low resistance or continuity when you measure it, It means the lamp still good.
I would contact the lamp vendor and let them know that the lamp failed. I think they gave some warranty on the lamp.
Let me know if you need further assistance.
Posted on May 17, 2008
  • Jaime Hernandez May 17, 2008
    Try removing the lamp and install it again. Sometimes an improperly seated lamp could cause the lamp to behave like is burn out.
    You might want to read a bit about other TV owners having the same problem. Click here.
    Novelist:
    Scholar:
  • 148 Answers
Those lamps can be pretty touchy and susceptible to temperature changes and finger prints. Also some discount lamp dealers can accidently sell you the wrong lamp. Something simple and dull to try is to take that lamp out and put it back in, check that the connections are seated properly and the air pathway from the fans is clear.  If the fans were dirty and you put in a new bulb that worked for a while it may have burned out prematurely.
  • Will Kibler
    Will Kibler May 24, 2008
    Those lamps are typically quartz arc and do not have a filament other then the starter. If the temp goes out of spec the quartz can crack and the arc will not propagate.
Where is the service menu for the bulb in the Samsung HL-S5087W DLP
if picture dim it is most likely the lamp and resetting the lamp timer will not help that.
Oct 14, 2012 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
I have a Samsung 56 in DLP that took a power bump and now will shut off after being on for only about two minutes. What can I try? It is protected by a surge protector so I don't think the surge went to...
Did you hear friction sound from behind unit?, if you hear it, change the color wheel.
Did lamp light before switched off?
and which indicator led in front side are blingking (Lamp ,Temp or fan).
If Lamp, chech the lamp.
If Temp, its mean hight temperature detected . check fan on engine, is it rotate smoothly or not, change that fan if necessary.
If Fan, its mean fan not working.
Thanks
Mar 15, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung tv model# HL-S5679W all three lights on front panel blink, no pix or sound owner's manual says lamp may be defective this is a DLP-LED. No conventional single lamp
The "lamp" in this set, I think, is called the "DLP" in the parts listings. That part is number: 4719-001960 and can be purchased from tritronicsinc.com for $249.75 plus shipping. Use the guest account to access this info.
Hope this helps,
Dan
Feb 17, 2010 | Samsung DLP HL-P5663W 56" TV
I HAVE A 50'dlp SAMSUNG TV-HL-S5087W THAT TURNS OFF
probably a bad (intermittent) control board.
Nov 14, 2009 | Samsung HL-S5087W DLP TV
Screen blacks out on samsung DLP
It may be a loose conetion inside the set. Open and carfully check the conections.
Aug 20, 2009 | Samsung HL-S5087W 50" HDTV
We have 2 problems....dark screen/bright light on right side
Replace the light engine. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W Shuts off
check the vertical amp section
nuwan.
Nov 05, 2008 | Samsung HL-S5087W DLP TV
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
May 08, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
88 people viewed this question
Henry  Thomas
Henry Thomas
