Question about D-Link AirPlus DI-524 Wireless Router
Can't enter "admin" as user name to setup router.
  • 629 Answers
By default "admin" is the user name and the password is blank. If this does not work, try admin as the user name and password as the password. if the same thing, it can mean that another password and user name has been set up. You may have to reset the router to its factory settings, usually, there is a small hole or button that you can press to reset to factory settings.
Posted on Sep 16, 2010
How do i log in for the first time
Basic step for login Linksys Router :
  • remove the router and modem power plug.
  • connect your router with modem.
  • power up router and modem.
  • open the Web Browser - 192.168.1.1
  • username- admin or blank and password- admin.
that's all for login
if looking for more help http://support.linksys.com/en-apac/support/linksys and Router Support for setting up your router setting.
May 19, 2014 | Computers & Internet
How do i set a password
Router's password could mean 2 things. First password for you to open router's configuration page or password for you to connect wireless to your router.
Configuration's password:
-Logon to your router configuration page
-Please to the TOOLS and ADMIN Tab. You there you can change the admin user name and password. If you do not have the user name and password, please check for the default user name and password on the router's manual. If default user name and password won't work reset the router. Press and hold down the reset button or pinhole on the back of the router for 10 seconds. Then re-enter user name and password again. It should work this time.
Wireless Security Password:
-Under SETUP and Wireless Settings tab you will get an option to change the wireless password
May 21, 2011 | D-Link DIR-615 Wireless Router
I forgot the password for entering configuration setup of my MEDION IEEE 802.11g/54Mbps Wireless Router, so I can't enter or reset the router. Thank you in advance!
use a paper clip to press the factory reset button, the usual default user name is admin and the passwore is usually either left blank or admin also
Jan 05, 2011 | Computers & Internet
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
How do I change the password on the Actiontec wireless router? (Not the WPA key, but the web interface password. I just want to change it from the default "password1")
  1. Open a Web browser. In the “Address” text box, type http://192.168.0., then press Enter on the keyboard.
  2. The Web Configurator’s “Main Menu” screen appears. Select Setup/Configuration.
  3. From the Setup/Configuration screen, select Admin Username/Password from the menu on the left side.
  4. The “Change Admin Username/Password” screen appears. Enter a new user name (optional) in the “New Username” text box, then a password in the “New Password” text box. Re-enter the password in the “Re-enter New Password” text box. Make sure to write the user name and password down and keep them in a secure location.
  5. Click Save and Restart at the bottom of the screen.
  6. The “Save and Restart” page appears. Click the Save and Restart button to save the settings changed in the Change Admin Username/Password screen.
  7. Once the Gateway has rebooted, the password is active.
You can also download a user manual from here, or - if you have any more questions - just come back here and leave a comment - I'm happy to help.
Jul 04, 2010 | Actiontec GT704WG Wireless Router...
Cant hook to wireless all in one
you will have to log into the router to setup the wireless device you want to allow access to.
moz-screenshot-11.pngcheck your user manual to setup your wireless
loin into the router by going to a browser and typing 192.168.0.1 or 192.168.1.1 enter "admin as user name click ok. this will bring you into the routers GUI (Graphical User Interface)
May 15, 2010 | NetGear WGR614 Wireless Router
Can't get to wireless setup page.Set network name &security
you can use default ip 192.168.1.1 go to this page from internet explorer, then they ask you for user name and password just you type ADMIN/ADMIN then enter.. after you can change your any setting.. hope to solve your problem...
Apr 29, 2010 | NetGear WNR1000 Router
Need to configure for wirless setupnew dsl line from one isp to another need to set up router for wireless connection
If you are setting up a new router for DSL connection, i presume that you already know the login credentials to access your router's admin interface. By default, depending on your router's model, you can access and configure it at http://192.168.1.1 or http://192.168.0.1 using a web browser and make sure that computer you are using is connected to the router through an ethernet cable.
Default login credentials:
user name: admin
password: admin (or try also leaving it blank)
When you are at the web interface, go to a link known as SETUP and there you can setup your connection. If your DSL provides you a user name and password, then you can also enter them there. Then save your settings.
To allow internet broadcasting using wifi, go to a link known as "WIRELESS" and setup encryption there using WAP, WPA2, or WEP or any other recommended encryption protocol. Through this, you can prevent other users near your place to use your internet connection without informing you.
Feb 04, 2010 | Computers & Internet
I do not have the installation wizard CD. Can I download the installer online?
YOU DONT NEED A CD TRY THIS
Point your Explorer at http://192.168.0.1
The Router default Username is admin
the default Password is just pressing Enter
Now you can accessRouter setup.
if it's new device, default user name and password are :
user : admin
pass : [blank
Dec 27, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Username and password needed
user : admin
pass : [blank]
Dec 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
