Question about Toshiba Satellite M305D-S4829 Notebook
My computer just keeps on turning on and shutting off and I can even get it to boot up completely. What can I do.
    New Friend:
  • 38 Answers
Power problem?
make sure battery is charged and charger works
charger may be faulty
Posted on Sep 16, 2010
Garmin 178C Boots up then shuts off
I've had a similar situation with a Magellan, it would power off despite being plugged in.
Its usually a battery issue, perhaps its not getting enough power? You could try to unplug it and do a "hard battery reset" depending on the type of battery. Keep turning it on and let it run out, until it wont even turn on anymore, after that plug it into a charger while off and allow it to charge completely. Turn it on, see if it still shuts off.
May 26, 2009 | Garmin GPSMAP 178C GPS Receiver
My computer is turning on and off continually
download memtest and burn the iso to a cd and boot from it to test your ram, it usually only takes a few minutes to see if your ram is bad or not, otherwise ive had computers with bad system boards (blown capacitors) that reboot themselves, and also computers that are overheating reboot themselves, check to make sure all air vents aren't blocked and that all of your case fans run well
Feb 19, 2009 | Gateway GT5220 PC Desktop
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
No "press any key to boot from cd" message
ok if it is windows xp and u want to format it then what u can try is that if u have the option for the complete pc restore,then what u need to do is that shut down the computer completely and then all u need to do is that shut down the computer completely from the power button and then press and hold down the "ctrl" button and then press the power button only once and keep tapping the f11 key on the keyboard....and follow the instruction that says complete factory setting and then it will give u some message from symantec and then click on ok and the computer will be format,all u need to do is follow the instruction very carefully.....
or u can try once again,shut down the computer and then press the power button only once and keep tapping f12 key on the keyboard and then highlight the cd drive and then put nthe xp disk in and keep tapping enter and enter and enter untill it will take u to the windows set up screen and then it will give u the option to press R to repair and esc to continue and press esc on the keyboard and then delete all the partition the instructuin will be given just read it carefully and it will be formatted........hope this will work take care...
Jan 27, 2009 | Microsoft Windows XP Professional
Won't complete booting
Sounds like at the very least, the hard drive is. This is common when a file required by the OS is corrupted, and the OS tries to not damage data so it restarts or shuts down.
Jan 18, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Turns Off
I am thinking 1 of three things first off acers are very nice computers but hard computers,I have seen this promblem before,you are going to have find a search and remove promgram for this spybot and completely remove it from your pc, it sounds as though it is causeing some conficts between software and your computer isn't listening to you....You mite try www.MajorGeeks.com
for free removel software of some sort after removeing it I would suggest completely shutting it down and re booting it,after that try reinstalling your reboot disc (but, make sure that you go into bios and set up download from cd rom ) don't forget to unhook any unnessarry hard ware such as scan drives printers and usb port items or it will cause more nuts then now. lala linda
Jun 02, 2008 | Acer Aspire 3000 Notebook
The PC doesn't completely boot up
u shoudl use xp cd and boot in formatt hard drive fresh install of your os
Jan 28, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computer wont completely boot
Nope a bad battery will not keep a machine from booting..
Does it shut off or do you get an error or does nothing come up when you turn it on???
Dec 18, 2007 | Computers & Internet
Problem to log in.
Start up in safe mode pressing F8 on boot up and select safe mode. When in the system under administrator there will be option for you to delete the password on your account. Re boot then enter again with no password.
Feb 22, 2007 | Toshiba Satellite M100 Notebook
Toshiba Satellite M305D-S4829 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
