Question about Homelite Garden
I need replacement battery charger for Homelite UT 20683 gas trimmer. Any brand that will work?
5 Suggested Answers
mrgauge
  • 17 Answers
SOURCE: need head for older homelite trimmer. ut 200. what
If you are talking about a ST 200, ( I don't think there's a UT 200 trimmer, "ST" means "String Trimmer") heres the head you can buy:
http://www.odonnellsautoparts.com/servlet/the-16894/Mini-Bump-Feed-Trimmer/Detail
Posted on Oct 01, 2009
rycgl
  • 1545 Answers
SOURCE: Homelite trimmer ut 15151 How do I replace pull
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers
Posted on Nov 10, 2010
  • 454 Answers
SOURCE: i need to know the gas / oil mixture for my
Usually says on the gas cap. My guess is 50:1.
Posted on Jun 11, 2011
SOURCE: I was given an electric start Homelite line trimmer, Touchstart UT-20683. Its like new condition but mising the wall charger. I need to know the voltage requred to charge the battery. Does anyone have
Funny I picked up one today...for $20. It too is missing the wall charger...it I find one I'll let you the source, meanwhile the voltage is 6. Hope this helps. I'll keep you posted Re: the charger..
Posted on Jun 23, 2012
I took my homelite trimmer apart to replace the clutch, but now can not get the engine housing to go back on, is there a trick to this ? Model ut33600a
Hopefully this will help if not go to homelite.com ordreing parts then select homelite then string trimmer then find your ut 33600a
Jul 15, 2017 | Homelite Garden
Jun 22, 2012 | Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
Aug 04, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to guitar0589@comcast.net. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
Jun 28, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
I need a manual for a Homelite Mightylite 17 inch Curved Gas Trimmer with EZ wind Bump Feed UT 21907 Ser #642287
Go to homelite.com then click on service and support, then click order parts then click launch homelite parts catalog, Agree to terms then click continue under model no type in mightylite then find you trimmer in list.
Apr 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
230 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
