Question about Sharp 25H-M60 TV
When the power button is pressed, relay RY701 clicks to engage, nothing happens and then RY701 clicks to disengage. I have checked the power input fuse (F701) and it is good.
Starter engaged while driving would not disengage. I turned key off put a new starter on now have lights power but nothing happens when turn the key whats going on? please, someone, tell me something.
Bad ignition switch. I have seen lots of these go bad. Also check starter relay. What happened was for some reason the starter relay was activated and sent a signal to the starter to start the car even though the car was running
Jun 09, 2017 | Cars & Trucks
Hp 7960 printer
Make sure the paper try is properly attached. Try to unplug the power of your pinter and the USB cable for about 2-3 minutes. Restart your computer. Plug the USB and power to the printer then turn it back on.
Oct 04, 2008 | HP PhotoSmart 7960 InkJet Printer
AC compressor always engaged.
disconnect the wire at the compressor to check that the clutch is releasing,then with a test light check to see if power is present when it is switched on and no power when off.
Aug 09, 2014 | 2004 Pontiac Grand Am GT
I have a 94 Acura Integra LS 1.8 DOHC. I bought it 4 months ago. The cruise control and horn don't work. I would be very appreciative of any advice that may help. The green light on the cruise button...
The cruise control requires input from the speed sensor(s) in order to engage. This may not be happening.
The horn relay may be clicking but the horn may have failed. The horn is located under the hood.
May 22, 2014 | Cars & Trucks
I am getting either an E6E 0r EbE code on my affinity washer . I hear the relays clicking but nothing happens .
Hello chuckthom980 - Typically EBE indicates that there is an issue with the console control. Contact a professional to have the main control board replace.
Sep 30, 2012 | Frigidaire GLTF2940ES Front Load Washer
I have 98 Saturn sl2. The cruise control works intermittently. I set the cruise and it will engage for about 20 to 30 seconds before disengaging. Sometimes it won't engage at all unless I repeatedly...
Testing the electrical inputs to the control module from the switch . Testing power an ground circuits to the switch . As a professional technician this is how i go about find what is wrong ! Not just replacing parts , that gets expensive. Do you know what a wiring diagram is ,an how to use one to pin point areas to do testing ? Here is a site for free wiring diagrams . http://www.bbbind.com/free_tsb.html Enter your vehicle info. Year , make , model and engine size . Then under system click on Engine , then under subsystem click on speed controls . Click the search button , then on the blue link . You will see all the componets an wiring for the system . Do you know how to use a volt meter ?
Electric Testing Techniques You Need to Know
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
96 98 Chevy pickup cruise control not working part 1 test module inputs
Apr 15, 2017 | 1993 Saturn SL2
1996 BMW E36 Convertible to stopped working.
Change switch first checking all contacts(wires to clips)
Jun 25, 2009 | BMW 318 Cars & Trucks
My a/c doesn't engage in 04 Grand caravan 3.3L V6 Ann. Edition
The most common problem that happens with a/c units in vehicles is that the clutch goes out. While the vehicle is on, you can have someone press the a/c on button while you're watching your a/c compressor. In the front of the compressor, you can see the plate engage/disengage when functioning normally. If you would like to get the specs for your vehicle free of charge, try www.autozone.com/ You'll have to register for an account, but it's a free service. If you need more help, just send me a comment.
Best Regards,
Jerry
Apr 28, 2009 | 2004 Dodge Grand Caravan
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Televison & Video Logo
107 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
