Question about Sony KDS-R50XBR1 50" HDTV
I have a Sony 50" LCD projection TV. It's slightly older than 4 yrs. now. My problem is the Power/Standby light blinks green when I try to turn the set on, which is typical, but the picture only comes on briefly then off, with the Power/Standby light blinking red, repeating a 4 light blinking pattern. I bought a new XL-5100 lamp from Sony, but it did not correct the problem. Is there anything else I can try? Thanks, Jim Coley james.coley@sbcglobal.net
    President:
  • 1,284 Answers
A four flash error sometimes means one of the fans is bad or clogged so much it won't rotate. You probably will have to remove the back and visually see if the fans that are visible are rotating. There is also the main lamp fan that is located in the housing to the left as you take the back off. This fan is not easy to get to at all as it requires a bit of a tear down to get to.
Posted on Sep 16, 2010
  • 3 Answers
The main fan in my R50XBR1 50" TV runs for about one minute -- after I shake it a few times -- and then quits. I have already replaced the lamp and the T1 board and even ordered a T3 board, I just ordered a replacement fan hoping that will fix the problem. If it does, I will return the lamp and the T3 board.
Posted on Apr 01, 2011
  • Sony Master
  • 17,129 Answers
Possible that the main convergence board is having issues.
The power supply is working OK and tthe standby indicates that the microprocessor is also working.
So you migh need to take a first hand view to look into the set to confrim if there is any visible signs of damage, a leaked capacitor, a open power resistor, shorted semiconductor- power-, heating in IC's. these can be relative to the fault as a first hand infomation.
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
When I try turning on the TV the power/standby light flashes green until I turn the TV off, no picture appears.
If Sony KF-60WE610 does not show any Red blinking light then it is Lamp that need to be replaced because existing lamp has reached to end of its life but still not dead nor broken and causing problem.
If lamp got dead or broken, tv will show you Lamp light blinking.
Replace lamp in tv to solve its problem.
Hope these info will help you.
Please buy Sony original lamp for good picture in tv.
Let me know if you have any question.
Thanks.
Nov 04, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
My Grand Wega KFE50A10 has a black screen. When started the power/standby light flashes green and the fan starts. After a period the same light starts flashing red in blocks of five. What does this...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2400 you can find it here:http://www.discount-merchant.com/Sony-XL-2400-Lamp-F93087500-Bulb-A1129776A-p/sony_xl-2400_f93087500_bare.htm?Click=48173 .Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDS-R50XBR1 50" HDTV Logo
716 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
