Recently, My LCD TV- KLV-40V400A has started giving trouble- like only picture is coming but no sound. I bought it through reputed vendor in Aug'2008. Pictures in all the channels is very clear but without sound. What may the problem and how to rectify. Please let me know the reputed service cente in Noida. What will be the economical repair cost suggested for to over come this problem.My contact number is 011-24361935.Looking for your best advice . Thanks. My e-mail address is NATHS@iocl.co.in
SOURCE: No picture and No sound
I have the same problem here with my Philips 30PF9946/37
I'm not sure this can be diagnosed as an inverter failure, unless there is a another inverter board in there I'm not aware of. The only inverter I found (actually two) in this unit is the pair of KLS300A1 inverters which drive the CCFL tubes.
Since I personally get a green power and light AND the CCFL backlight comes on, it seems unlikely that the inverters have failed.
Would love to hear from anyone who can ident the failure in these units - there's certainly a LOT of these around that have failed in exactly the same way.
Posted on Mar 16, 2008
Mark_Webber
  • 472 Answers
SOURCE: LCD monitor produces some bursting and cracking sound. Service centre or technician address req
One of your CCFL tubes inside the monitor is broken.
This causes arcing at the connector to the powerboard of the CCFL tube.
It would of suffered a drop etc in transit for this to happen. It is extremely rare they just break like that new.
Contact your place of purchase, and they should be able to arrange a swap immediatly.
Posted on Apr 19, 2008
  • 3422 Answers
SOURCE: Hanns G LCD monitor produces some bursting or cracking sound.Requires reliable service centre or techicians address
HI,
I'll let you know soon...
SOURCE: LCD TV SOUND BUT NO PICTURE
Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Posted on Jan 01, 2009
SOURCE: LCD TV PICTURE HAS GONE OFF BUT NOT SOUND?
when ours went the repair man went over boards on back with magnefying glass and replased 2 capacitors that had blown £20.00 he charged us
Posted on Jun 19, 2009
Sony KLV 42EX410 LCD TV works but no picture.sound is ok.
LED driver is the most common cause. You should be able to get replacement parts from www.tvcircuitboards.com they can assist with troubleshooting why the LEDs are not lighting
Jan 09, 2013 | Sony 42 inch KLV-42EX410 Multi System LED...
My 2 years old Sony LCD TV (model # KLV-32S400A), while it was working, went OFF (no picture and sound), refer the trouble shooting manual, switch OFF and ON again found in stand by mode LED was blinking 8...
Ask the dealer because this kind of repairs should be must warranty on hidden defects, a television is made for a lasting time between 4 and 6 years then yes lead free solderings and are they reliable ???
Its very strange that SONY is having in between 2 years a defect.
Its much to early for a real Sony .it was no old refurbished second hand or a forgotten older model ?
Very Important is this is to realize in case of trust was it the intention of the technician to sell you a new t-con or a refurbished one ? thats should in many cases the weak point if you look on that refurbished board that exact the same problem with the same ic could happens then for shure there is a hidden defect. its easy to see where was repaired on the board.
The replace of the lcd panel is maybe guesswork on the fcc cable connection sheets it should only to be replaced if there where vertical lines somewhere
If no warranty is give on hidden defects by the dealer write to Sony A solid complaint.
The dealer is the first contact let them inform a representative of Sony regarding this complaint, the four-year minimum healt of your tv was not reached, you as a customer is entitled to a good product that is expected at least four years. warranty on parts wages in leniency possible but not required.
Questioned about that dealer: are they commercial boxes sliders or solid proffesionals where you just pay and get service without having to smoke a cigar from your own box
SONY KLV 26S400A KLV 32S400A KLV 37S400A CHASSIS EG1L GA EXPLODED WIEV NO...
Mar 26, 2017 | Televison & Video
Sony klv32t550a lct tv probllem: tv sound ok but no display and video
dear User,
supply board isshue.kindly take off your rom lite then check if dim picture is coming then its supply issue
Feb 10, 2011 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
Sony KLV-32M1 LCD TV switches off/on
in this situation autoshutt off in few seconds no sounds and pictures. you have to check the secondary power supply. check all capacitors. budged capacitors can make shutt off sytem. capacitors blown on top due to hot pressure inside tv.
Jul 08, 2009 | Televison & Video
Sony KLV-S32A10 32 when i turn on picture come then goes off
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Jun 09, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
My Sony Bravia KLV-32U300A 32 in. HDTV-Ready LCD TV just lost the picture. Just see different colors. Hears static sound from the back of the unit. This was a progression. Few days ago, clicking sound...
hi..It's probably a loose cable. The first one to check is the
green connection but make sure they're all tight. RCA cables
tend to pop out part way which is enough to stop the signal.
If the green signal is lost, you get no picture. If the red or blue
are lost, you get a picture with bad coloring.
If you still have the problem check this
LOOK in the back of the TV when you have it turned on. Look in the slots near the top for a white glow coming out of it.
IF you see it, you need your signal board replaced...
IF NOT, then you need your power supply board replaced...
Apr 19, 2009 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Apr 08, 2008 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
SONY KLV30HR LCD TV RED EFFECTS
You probably need to replace the backlight. In parts less than 30$. If you know your way around these things, or know someone who does, it's not a super difficult thing to do. You can get a tutorial that's written for monitors here: http://www.inventgeek.com/Projects/shorts/lcdfix.aspx basically the same procedure for an LCD TV. Good luck!
May 20, 2006 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
