Question about Sony Ericsson K750i Cellular Phone
CAMRERA NOT OPENED & MOBILE NOT CHARGING - Sony Ericsson K750i Cellular Phone
Fix
It sounds like the battery is not actually charging.
Here is the manual, checkout page 40
http://resources.kodak.com/support/pdf/en/manuals/urg00967/M320_xUG_GLB_en.pdf
Here is some guidance on charging issues
http://support.en.kodak.com/app/answers/detail/a_id/18364/src/gousbcharging/selected/true
Jun 04, 2013 | Kodak EasyShare M320 Digital Camera
Nokia 3125 dead set plz help me
If your mobile is dead then please check is it charging or not if it is charging then it means your mobile is not dead it is just software problem for that you should reinstall the software it will start working. & if it is not charging then there is a problem with your mobile mother bard for that you should visit your nearest Nokia service center they check what happen to your mobile & they will solve it.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 20, 2011 | Nokia 3120 Cellular Phone
What dead solution
Regards,
Harish
Jun 20, 2011 | Nokia 5310 Cellular Phone
I download anyware software's in nokia5130 & install it's game application in my nokia5130.i opened it but it's messege given that suporative file can not be opened.please solve my problem.
its not a problem because some mobile games demand high requirements for playing and your mobile does not support the games so plz download suitable games for your mobile and then play the games
Jan 06, 2011 | Nokia 5130 Cellular Phone
While charging mobile restarts again and again
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2010 | Samsung Star GT-S5233 Cell Phone
No display to indicate battery is charging Nokia E63
to confirm that the phone is charging, switch on the mobile and charge or turn on the mobile when it is charging.if it doesn't works then try with some other charger,still same there is some problem with the battery r the connection point.check with the vendor.they will definitely assist u.
Aug 19, 2009 | Nokia Cell Phones
Htc p3400i windows mobile....Battery Charging Problam!
I am also facing the same problem with my O2 XDA mini. It seems to be the problem with the battery/charger. Are you using genuine battery/chargers that came with the phone? I am using a local battery so assume that it has to do something with the battery itself.
May 12, 2009 | Cell Phones
My nokia 1600 is not charging.......
clean the charger connectors against the phones mainboard (phone needs to be opened)
Oct 21, 2008 | Nokia 1600 Cellular Phone
NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Feb 16, 2008 | Nokia 6630 Cellular Phone
Charging problem?
your firmware needs reflashing, take the phone to any mobile service center and have them do it for you.
Jan 30, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Sony Ericsson K750i Cellular Phone Logo
27 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
