Question about Sanyo DS27910 27" TV
No remote i need to change the channel to input and i dont have the remote and i do it manualy??
  • 975 Answers
Most cases you need the remote , heres a link in case you want to buy one,
http://replacementremotes.com/store/index.cfm , hope it helps AJ
Posted on May 17, 2008
I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Jul 18, 2011 | Televison & Video
I need to know how to hook a playstation 2 to this t.v if I dont have a remote control. It does not allow me to get an input.
you have to go to setup, channel select, and change the channels from there to the input........otherwise the only option would be a remote
GOOD LUCK AND PLS RATE THIS POST!!!!!!!
Feb 24, 2010 | Broksonic CTGV-5463TCT TV
Changing chanal
Perhaps channel 4 is the only channel programmed? Try reprogramming your channels. Perhaps a universal remote would give you direct access to the channels. Your channel up or down won't work with only 1 channel programmed.
Jul 24, 2009 | Televison & Video
I only Get Channel 3 and a blank screen that says LINE
Under the menu setup, set it to cable (not "air")and do the search again. If there is a button on your remote that says input, push that first before trying this. Might save you some unneeded steps. Good luck.
May 22, 2009 | Panasonic PV-C2541 25 in. TV/VCR Combo
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
No connection DVD to G25189TK. No external channel set. (3 or 4)
to see the dvd video you should select the AVmode using your TVremote.if the wires are not properly connected you cant see the picture or video.try to connect the wires in the front panel or the back panel.try to connect the wires as per the notes given as audio input,video input etc.
Dec 06, 2008 | RCA G27647 27" TV
Can't change TV to AV input.
dont bother trying to do it but then i got the same problem :)
Nov 30, 2008 | Televison & Video
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Auto channel programming
The desgin of this unit is such that only the channel being recorded can be viewed. Try to manualy program channel 3 - p.25 in the user guide.. Good luck.
Jan 14, 2006 | Panasonic PV-M2048 20 in. Combo
Sanyo DS27910 27" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
