Question about Canon PIXMA iP90 Mobile Printer
My printer Canon iP90 does not print black color. Advise what to do. Thanks.
  • 629 Answers
Chances are, the blank cartridge is empty and needs to be replaced. if it is new, make sure the plastic cover is removed from the cartridge, try to remove the ink cartridge and shake it a bit and connect it back, then check your printer settings to verify if it is set to print in blank ink/color.
Posted on Sep 16, 2010
5 Suggested Answers
SOURCE: Canon iP90 Printer Problem
I have 2 MP 390s. On one the print head is stuck on right and does not move. On the second the black ink does not print but everything else seems to be fine. How can I remove the print head from the stuck machine and place it on the other one?
Jake, Florida
Posted on Feb 12, 2008
ginko
  • 19396 Answers
SOURCE: Canon iP90 only prints blank pages
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Posted on Apr 27, 2009
pineworks
  • 4041 Answers
SOURCE: My Canon ip90 is 5 years old. It prints color but not black.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 07, 2010
  • 130 Answers
SOURCE: I have just replaced the
make sure that you have installed the black cartrillage properly ....if not simply remove it and install again ...and do rub the ink side of the cartillage on paper to make sure that it is properly working....after that check the roller through which the paper rolls and comes in contact with the cartillage
Posted on Jan 21, 2011
My canon iP90 prints in color but when I want to print a picture it comes out in black & white what should I do to get color pictures
on you pc go in start pinter settings. right click on the priner
go in properties. you will find there a option for gray scal or colour.
Oct 14, 2011 | Canon PIXMA iP90 InkJet Printer
I have just replaced the black ink in my canon ip90 printer and there is still no black being printed? can you advise?
Jan 21, 2011 | Canon PIXMA iP90 Mobile Printer
IP90 won't print black. Replaced ink, deep cleaned heads, etc. Will print color, but not black.
You probably need a new printhead, but there is also a new update for that machine to help clean the black part of the printhead. QY6-0052-000 is the printhead #
Sep 24, 2009 | Canon PIXMA iP90 InkJet Printer
Ip90 printer does not print blac on a test after
Sounds like the printhead is plugged on the black side. A new printhead is #qy6-0052-000 around $40.00. That model also needs a firmware update to help it clean the printhead better.
Jun 23, 2009 | Canon PIXMA iP90 Mobile Printer
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
IP90 WONT PRINT BLACK
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Canon iP90 Printer Ink Issue
I have had the same issue with my iP90.  I think this results from the black ink nozzle becoming clogged.  I was able to get mine to print by cleaning the nozzles.To clean the print nozzles open the Canon IJ Printer Utility, select the printer from the list of available printers and click the maintenance button.  Then, select a cleaning or deep cleaning cycle.
Jan 02, 2008 | Canon S 330 InkJet Printer
My ip90 Canon printer only prints in purple
Try selecting an option in the printing properties to print in grayscale or black and white (you usually only have either one or the other). This will utilise ONLY the black cartridge, the color will remain dormant which should make your prints come out in black and white - if not, your black cartridge, or the space between the bottom of the black cartridge and the paper is contaminated with color ink. Good luck!
Sep 07, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
150 people viewed this question
old marine
old marine
