Question about Dell Inspiron 1150 Notebook
Monitor Suddenly Shuts Down
About 2 weeks ago my monitor suddenly started shutting off. The rest of the computer is still running. It only does this when the power cord is plugged in. If it is running on the battery it works fine until the battery runs down. I downloade an update for the video driver and bought a new battery. Same thing.
Help!
  • 37 Answers
You should download and install the software for your computer model that controls the functions like increasing & decreasing screen brightness, switch between screens etc. Try reinstallimg the OS using the recovery CD ROM that came with your computer
Posted on May 17, 2008
My laptop shuts down suddenly
Is it overheating? Is the fan and vents clean and allowing sufficent air flow? Was it left unattended and shut down? If so change Power settings to High Performance, change Sleep to Never, Change Hibernate to never. I don't know your OS to give detailed info.
Dec 06, 2012 | Dell Computers & Internet
Hp g72-260us suddenly shuts down on battery power only
your power setting is not work perfectly going to your battery option and click that then you setting power capability.
Feb 17, 2012 | HP Audio Players & Recorders
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Sceptre x24 has suddenly stopped working. Monitor
if you are using integrated video, your integrated video is fried, done gone. if you have a pci or pcie or vga video card, its gone or blown or dead as a doornail. replace the video card and youll be up and running again
Jun 04, 2010 | Sceptre X24WG-NAGA Monitor
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages (acer.com). In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto http://www.cpuid.com/hwmonitor.php and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Monitor turns on for less than a second, then off. I bought a 19" Samsung LCD monitor (953BW) about 10 months ago and the first time I used it, it would only switch on for a split second and shut down. ...
Although the OP was 2009. I had this problem.
I simply replaced the power board. Which I bought from ebay for $20AUD.
It was real easy to remove as well. Just have a look for youtube videos.
Fixed!
Aug 31, 2009 | Samsung 953BW LCD Monitor
Fujitsu-Siemens Monitor problem
usually shut down when idle(idle means no key or mouse activity).........left click mouse in any space on desktop,select properties,in properties window select screensaver and lower in the screen youll see power settings..select it...in power schemes change time best suited or select never.
Feb 24, 2008 | Computers & Internet
MY LCD SIEMENS 15
I CONNET IT FROME POWER SPPLY (12 .V) IT WORKE BUT AFTER FEW MIANETS MONITOR ECIME WHIGHT WITH GROWPE LINES RED AND GOOWPE LINES BLUE COMEING AND GO QUKLY
Feb 24, 2008 | Mag Innovision LT776s 17" LCD Monitor
Dell Inspiron 1150 Notebook Logo
110 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
