Question about LG Washing Machines
My LG washing mahine model WD-8007 C1 vibrates excessively(sometimes) when spinning at 800 rpm. It runs well otherwise, I suspect that the two dampers (shock absorbers ) fitted below the casing ( assembly with motor, belt drive and rotating drum) is probably worn out and needs replacment.It was purchased in 2003 and has been im use daily for about one hour since then. Please let me know how to remove the dampers and how to check them whether they need replacement.
5 Suggested Answers
SOURCE: suspect drum bearings
LG Direct Drive bearing replacement The following guide is written to help you assess if replacing the bearings is a job you can undertake and complete. This is not written to be specific to any particular direct drive model but it will help in all cases.
Must do's Before commencing work on an electrical appliance:
1) Unplug the appliance from the wall socket, ensure the appliance on/off switch is in the off position.
2) Turn off the inlet water at the isolation valves and disconnect the inlet hoses from the appliance.
3) Clear a space and plan where you are going to put items you remove from the appliance.
4) Have pen and paper handy for making notes, a digital camera is ideal for taking a picture of wiring connections for future reference (**PHOTO**)
Strip down 1) Remove the worktop by undoing 2 screws at the rear, slide backwards and lift off.
2) FROM THE BACK.....Remove the back panel (4 screws) giving access to the rear of the tub unit. Disconnect the wiring to the motor, thermostat and heater, disconnect earth wires, (**PHOTO**). The drum pulley, which is the ROTOR of the direct drive system has a single bolt to undo. Slacken this bolt a turn or two, DO not remove completely. Gently tap the bolt with a soft faced hammer or drift, this will assist in the removal of the Rotor. Remove the bolt and remove the rotor, careful as it has a series of magnets around its inner circumference. The stator of the direct drive system is now in front of you, there are 6 bolts holding it in place. Remove these and very carefully remove the stator without damaging it, its very expensive, look after it. Depending on your model there could be a spacer between the stator and the tub unit, if so remove this also.
3) FROM THE FRONT.....Open the filter door (left side of kick plate) if there is a small drain hose, remove stopper and drain off any water in there. There is 1 screw to remove which is at the side of the filter, then slide the kick plate sideways should release the plinth from the cabinet. Open the door, the seal clamp band that secures the door gasket to the cabinet should be removed. If the door seal has a further hose attached, remove it.
4) Read all of this paragraph, there are 2 versions.....Remove 3 screws holding the lower edge of the front panel to the cabinet. Remove the soap drawer, remove 2 screws in the control panel that secure the soap box, depending on model there could be a third in the lower right hand corner, if there is, remove it. If there isn't read on further.. Carefully slide the front panel downwards about 20mm and it will disengage from the cabinet, carefully look behind it and disconnect the door lock wiring to allow complete removal. If there was not a third screw (lower right hand corner of the control panel) then the control panel will have to be removed. From the top remove the clip retaining the hose that goes into the top of the tub unit, remove the clip holding the large hose on the left, slide the soap box backwards slightly and hang over the back of the cabinet, all the hoses still connected. To remove the control panel look under the top frame and release the two lugs whilst easing the panel away from the cabinet. disconnect the wiring and remove away completely.
5) From the bottom remove the sump hose from the tub, the screw that secures the pressure bottle to the tub. Remove the suspension pins from the top position of the legs and push the legs clear of the tub unit. The tub unit will now be hanging from the top springs. Using strong wire or rope, loop the hook of the spring, lift clear of the cabinet and lower the tub unit to the floor. Repeat this on the other spring which then allows the tub unit to be lifted through the front of the cabinet.
6) Place the tub unit door seal up, remove the screws that secure tub front 1/2 to the rear 1/2. This allows the inner drum to be removed, if its tight use soft faced hammer, DO NOT damage the drum shaft.
Inspect the drum shaft collar, the collar is located at the base of the shaft and is the surface that the oil seal mates to. Look for indents or circular ruts where the previous seal has worn the collar away
6a70_2.jpg if damaged you will need a new spider unit. Do not clean up using abrasive cloth, try the green pan scrubber from the kitchen instead. If damaged and you don't replace it the bearing replacement will fail prematurely as the oil seal fails to keep the wash water away.
There are several different kits, comprising of 2 bearings and 1 oil seal. To obtain the correct kit you will need the model number of your appliance, eg WM1480FHD or WM1485FHD or WM16225FD
all use bearing kit 1 available here other kits are available for other models including belt drives and washer dryers
The bearings can now be removed, the seats cleaned and made ready for the new bearings and water seal. A light cover of grease can be smeared on the inner edge of the seal.
7) There is a tub seal which fits in the recess between the front and rear 1/2's of the tub unit, it is adviseable to renew that seal before rebuild is commenced.
8) Rebuild is a reversal of the above, at every step double check electrical and hose connections and before you refit the cabinet front.
Hope you find this guide useful, some paragraphs can be applied to the belt drives also.
Posted on Oct 04, 2008
  • 1937 Answers
SOURCE: I have a top loading Kenmore 80 series Model #
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Posted on Sep 29, 2009
Testimonial: "The information is very detailed and I'm sure will be helpful. We'll know more once we check for damages to the springs on the cams."
NiftyInsight
  • 15 Answers
SOURCE: Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Posted on Apr 04, 2010
  • 670 Answers
SOURCE: I have a Frigidaire model FWTR647GHS0 washing
I have this same exact washer, and the noise of the bearings could be heard from the basement to the second floor. The noise gets louder and louder as the bearing fail. The ball bearings are no longer round but misshapen as they rust and pit. The drum will have more play since the bearings are no longer true but they wobble as they turn. Unless you see that they are physically broken, the shocks and springs are probally ok. So replacing them won't solve your vibration or noise problem. The bearings need to be replaced.
Frigidaire wanted $250 + shipping for the rear drum with the bearings. My machine was 9 year old and the grease from the failed seal was dripping onto my clothes leaving brown stains when I decided to have it fixed. I did not want to spend $250 on parts to fix a 9 year old washer. But instead, after tearing the washer appart and seperating the wash drum into the two parts I just replaced the two bearings and seal. I pounded out the bearings from the rear tub and pressed in new ones. It took about 6 hours and less than $70 to fix. It's almost two years since I replaced the bearings and the machine is quiet enough that during a spin cycle you can have an normal conversation.
If you have some mechanical ability and a friend that willing to help you you can do it too. I got my bearings and seal from E.B. Atmus Co. The ones you need are 6307-2RS, 6306-2RS and seal number is 15939-CR. I learned how to do it by reading this blog. http://www.applianceguru.com/forum2/834.html
Hope this helps you.
Posted on Dec 07, 2010
Why my washing machine vibrate when spinning
if it only vibrates when in the spin cycle turn off the machine and cloths distribution re-balance you have to many heavy cloths on one side of basket. Turn it back on and let it continue this should solve your vibration problem
Jul 13, 2015 | LG Washing Machines
Excessive vibration during spinning
I think it should be normal.One of our washing machines does it too.No problem so far.
Aug 05, 2012 | Malber WD1000 Front Load Washer/Dryer
My mahine is a LG :MODEL:WF-+857,CAPACITY:8.5KG,APP:NO:N19973
no idea without a look but i suspect the contacts on the motor armature
Apr 27, 2012 | Bosch Washing Machines
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
Excessive drum vibration
Yes, look into trading in the Kenmore for one of only two manufacturers that employ a dynamic balance system built into the washer drum. Samsung and LG both use this dynamic balance system that balances the load while it is in motion. They also use a vibration sensing system to modify the time and speed of the spin cycles to minimize any vibration that might still be present. LG has this available on only their upper level models while Samsung's VRT is available on most all models. I believe that both of these manufacturer's are available from Sears.
Oct 03, 2009 | Kenmore 43142 Front Load Washer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
LG WD-8074FHB frontloader washingmachine, vibration during spinning
As happened to me, it could be that one of the shock absorbers at the base of the unit has come adrift from its securing point.
Jun 23, 2008 | LG Washing Machines
Washing Machines Logo
83 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
