Question about Whirlpool DU1055XTS Built-in Dishwasher
Draining during wash cycle, so wash cycle does not complete
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Hi, thanks for using FixYa.com. I suspect you may have a siphon problem. This dishwasher must have some type of an air break or a high loop in the drain path. Try lifting the drain hose up above where it drains into the sink or wherever it drains to. Tie it there with a zip tie or wire. Just make sure it is higher than the drain hookup area.
Posted on Sep 16, 2010
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Model @16969990 Washing water doesn't pump out, cycle doesn't finish, attemptes to run other cycles default to "normal wash"
The drain cycle does not complete as the drain pump is not working the pump out the water. So unless the drain level comes down to reset the water level controller the program does not progress further.
So check the voltage during the drain cycle if voltage is present then the drain pump is faulty if not the main controller is faulty.
replace accordingly.
Sep 17, 2010 | Kenmore Dishwashers
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't complete cycle
It sounds like your water pump is going bad or is bad.
Nov 08, 2008 | GE WCVH6260F Front Load Washer
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Whirlpool DU1055XTS Built-in Dishwasher Logo
367 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
