Question about JVC Televison & Video
I was watching the tv when it just shut down, the blue light in the front of the set started blinking vary fast, the model # is hd52z576. from alex at foxfixit@gmail.com
  • JVC Master
  • 17,130 Answers
Possible failure in the main board as the power supply and the microprocessor is working fine.
The processor indicates the errror in the system as this can be very much speculative.
But it iwll be good to take a first hand look inside than to list a whole lot of possibilities. Check for visible damages, for capacitors leaks, for resistors open or for short in semiconductors.
Posted on Sep 16, 2010
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
I have tried to turn my television on and the status light blinks for about a minute, you can hear the TV try to start up and then the whole system shuts down without anything actually powering up. Also...
Unplug the tv for about a minute - plug it in and press the reset button on the front of the tv - hold it until the light blinks. The set should come on in a minute of two - if not try the same routine again.
Jan 16, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
My model is a WS-55511. I turn on the TV, the
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV will not turn on
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | JVC HD-61G587 TV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Our 52" widescreen LCD TV just quit working.
This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
Apr 09, 2009 | JVC HD-52G787 52" Projection Television
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
