Question about Nintendo Wii Console
Remotes neither of two remotes work,lighs flash,etc. Replaced sensor bar just in case, not the problem. Russ Wolfe,
  • mastersean93 Jan 09, 2009
    I have the same problem.
    When I press under the cover just like the nintendo website tells me to do it syncs up momentarily, but once I load up a game it loses a sync. Also when the wii turns off I need to sync it again after.
    Please help!
  • 30 Answers
Under the battery cover on the remotes and under the panel on the front of the Wii are sync buttons. If you press one and then the other (I forget the order) it will connect the remote to the Wii.
FYI: The sensor bar only affects the pointer function of the remotes.
Posted on May 19, 2008
Hi, Working with a Sears 1/2 HP garage door opener that can be activated by a wall button or remotes. No key pad. About a year ago, I replaced the old motor, since it only turned in one direction. I...
The opener will not work without the sensors. Make sure you don't have a broken wire going to the sensors. Make sure the small light on each sensor is lit and not flickering. If you cannot get both lights to come on you have either a bad sensor or a wiring problem. If the main light flashes 10 times it is definitely a door sensor problem. The wall control may be bad now from usage. Remove it from the wall and short across the 2 wires. If that causes the door to try to move you then know the button is bad. You can also short across terminals #1 and #2. That would eliminate bad wiring to the wall control. Make sure the connections on the back of the motor unit are tight and that the 2 white wires from the sensors go to terminal #2 and the white wires with black stripes go to terminal #3.
Mar 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a 1971 vw fastback the ignition switch was ripped out of so I bought a new one and need to know what wires go to what
For wiring help you will want to go to this link below and ask Russ Wolfe how to wire the switch. He will beable to tell you know problem.
Good Luck
Aug 28, 2010 | Volkswagen Beetle Cars & Trucks
Need owner manuel for koss KS5190 digital home theatre system
me too help Do u need remote to set speakers along with other setting problems including, back speakers not working, tv not on surround sound, can play dvd and tuner still no back speakers, no remote. Do u need remote to set, please help!!!! email
May 11, 2010 | Koss Audio Players & Recorders
Setting up Email Acct with Iphone
well to the first person unfortunatly the bellsouth email system is not yet designed to work with the 3g network so you would have to turn that off to use bellsouth.
Also for all of you need to remember that both Yahoo and AOL email work with the IMAP stands for Internet Message Access Protocol. It is a method of accessing electronic mail or bulletin board messages that are kept on a (possibly shared) mail server. In other words, it permits a "client" email program to access remote message stores as if they were local. For example, email stored on an IMAP server can be manipulated from a desktop computer at home, a workstation at the office, and a notebook computer while traveling, without the need to transfer messages or files back and forth between these computers.
where as the bellsouth system is a POP system. what the means is that when you check your email client on either the computer or the phone it is actually pulling the mail from the bellsouth server to the respective devices and deleting the email unless you have both set to leave a copy on the bellsouth server.
and again the sending and recieving issues with bell south is due to the 3g network
Dec 18, 2008 | Apple iPhone 3G
TTL Multi-Flash Sync Cord SC-27
Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
When I try to send an email with an attachment, I get and error mesage that begins "The host '' could not be found (etc)". I contacted AT&T who advised I contact you and...
well..this is NOT bellsouth, I can assure you, and this issue is clearly NOT a printer one. So, contact Bellsouth for this information about how to work your email program.
Aug 19, 2008 | Lexmark X2500 All-In-One Printer
Nikon sb800 speedlight
The trigger circuit and flash tube needs to be replaced . If you want me to repair this contact .
Berrie Smith Camera Repair
Mar 27, 2008 | Nikon Speedlight SB-800 TTL Flash
Operating Manual
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps. Ed
Dec 11, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Nintendo Wii Console Logo
19 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
